Terry Snyder:AFAIK, I can't buy AME separately. Or can I?
I'm pretty sure it's only available as part of the CC package.
Andi
ripvanmarlowe:I've had ProRes creation working fine on my HP using AME.
If AME can encode ProRes from a PC, it begs the question...why can't MC do it from a PC as well? I can't imagine a huge company like Adobe is scamming Apple, so they must have some licensing deal with Apple. Since ProRes is one of the most commonly requested formats, Avid should follow Adobe's lead.
I have a fantastic editing assistant. He stays by my side when I edit...doesn't talk too much...and thinks I'm a genius! Check him out here: www.youtube.com/watch?v=ZQVkYaaPO6g
Ultimately I believe we'll see more output options for export. But in the meantime, here's the workflow I use:
1. Edit the timeline to create the master sequence.2. Render the timeline ((you can't skip this step).3. Export an AAF using the following settings:
4. Open Resolve. Create a new project (or for me I just alter the properties for the default untitled project) and set the properties to match that of your timeline:
5. From the Resolve File menu select Import Timeline:
This will import all of the clips used in the timeline and recreate the timeline as it existed in Media Composer.
6. Go to the Deliver tab and set your output parameters as necessary. There are some pre-built options for YouTube, Vimeo, etc. that you can select. Here I'm using the YouTube 2160 template. NOTE - by default the output format is QuickTime .MOV. I change it to MP4 as that's what I want.
It really is a fast workflow. Notee that for really complex timelines you may end up having to mixdown the timeline in MC first.
Hope this helps.
Dave S.
Nice summary, Dave - do you have any words of advice if Resolve claims that the media is offline?
Steve
______________________
www.nelliedogstudios.com
And how to transfer any effect or audio keyframes from Avid to Resolve?..
sergiumm: And how to transfer any effects or audio keyframes from Avid to Resolve?..
Yep, resize, PiP, keys, slomo and speedup etc do not translate nicely, if You extensively manipulated things You'll be better off with a videomixdown.
peace luca
My workfllow - export QuickTime Reference, then TMPGenc Video Mastering Works - the last
constantly updated app that works with QT ref
I always SAS and then TMPGEnc.
It's a good idea to export also Panasonic AVC Long Gop 25 for net.
Not another encoder needed.
It's small and it is 422 10 bit. If you need that.
Very good Quality.
Desktop
Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
Laptop
MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
NLE
DR Studio 19.1.3|MC 2024.12
VDIM
BarkinMadd: Nice summary, Dave - do you have any words of advice if Resolve claims that the media is offline?
I like the idea of this Resolve workflow but in practice I'd be way too worried about something not translating between Avid and Resolve. I'd have to QC the Resolve timeline before exporting and this makes it a waste of time.
Mixdown > SAS QT master > strike deliverables through third party app like MPEG Streamclip or even faster, mixdown to OP1a and have AME make deliverables in background. Avid definitely needs it's own version of AME with a "Send Timeline to..." function with a set of common presets or watch folders and yes, ProRes on PC.
If I need ProRes and I'm working on a PC at the moment, then I'm paying for a CC subscription. Or buying a used Mac mini.
ripvanmarlowe: I'd have to QC the Resolve timeline before exporting and this makes it a waste of time. Mixdown > SAS QT master >
The PC here renders H 264 ad H 265 between half (worst) and a fifth (optimistic) of real time.
I do not use any linked media, not that that makes any difference if you are using mixdown sequences. From Avid media timelines I have never had a offline file on Resolve. This makes sense to as my AAF media is all Avid media in the Avid MediaFiles folder (using the Avid media databases) I believe Pro Res is an option with PC delivers from Resolve, I do not use it for anything myself.
Alayne
The workflow mentioned doesn't involve making a mixdown, it involved sending an AAF to Resolve and relinking the media. This is why I would now need to QC this timeline to double check that things like effects and speed changes have come across. You are suggesting doing a mixdown and then sending to Resolve, which is fine and a good option but not what I was referencing.
Some effect will not translate across. Some effects will. For example, the fade transition comes across without a mixdown whereas the PIP effect does not. When in doubt, you have to do a mixdown to be sure.
I'm not claiming it's a perfect solution, but it is a workable one.
There's no question that we ned far better options for output in MC. And at some point, I suspect that we will be seeing them. In the meantime, all we can do is offer work arounds for people to use.
Forgot to mention: You can't use QT Movie Same as Source for XAVC-S media. It's not an allowable resolution. So this is not an option.
And Avid did have something like AME. It was Sorenson Squeeze, till they discontinued the product.
If you need to do Prores, and you can't afford to get one of the Adobe products in order to use AME, take a look at Intertake by Acrovid. It supports creating Prores in a QT wrapper.
