Hello people,
I'm stuck, I'm can't open the sequence I'm working on when I load it MC is crashing, yesterday I could load a older version of it and worked all day on it, But now that older version is open and I get a crash right away the error code is
-----------------------------427C3C556A5D128C
Content-Disposition: form-data; name="Version"
18.12.5
Content-Disposition: form-data; name="ProductName"
Avid Media Composer
Content-Disposition: form-data; name="upload_file_minidump"; filename="minidump.dmp"
Content-Type: application/octet-stream
I'm on 18.12.5
Core
Cre...
I have never seen this before.....
I suggest you go to the support partal and create a case and have support check it for you.
Log in to your My Avid
MyAccount and you will see access to the support portal on the right upper box.
Thanks Marianna,
I saw now that it came together with something else my main media hard disk is not seen by the media composer
ii is online but MC doesn't see it so is part of the problem.
What the Disappeared hard disk causes I don't no.
Do a get Info on the drive and see if it is set for Read only.... if so, change to read/write.
Well I've been using this drive for years already and I can export clips to it, but in the media creation settings it is not there
I filder no drives out
