Latest post Mon, Apr 15 2019 3:40 PM by Terry Snyder. 5 replies.
Page 1 of 1 (6 items)
  • Sat, Apr 13 2019 11:20 PM
    Help! Audio Level is Maxed at +12 Still Not Loud Enough
    my sequence has five Audio tracks A1-A5 but A2 was not well recorded and thus not loud enough.  Sound quality is great but the level of A2 is not high enough.  I have the master maxed at +12 and A2 maxed at +12.
    I'd love to get your idea on how to solve this.  The balance is perfect between all five audio tracks so what i really need is some way to increase all five tracks a little...like if the master could go to +17 then everything would be just right i think.
    kind thanks,
    Domenech
    i9-9980XE; Asus Prime x299 Deluxe II; 128GB DRAM4; Nvidia Titan RTX; SSD 2TB [view my complete system specs]
  • Mon, Apr 15 2019 2:06 PM In reply to
    Re: Help! Audio Level is Maxed at +12 Still Not Loud Enough
    For this I add a Trim FX from the Audiosuite plugs.
    All PC Win 10 - 11 MC/Symphony Nitris DX 2018.12.5 - Interplay 3.6/90TB Mirrored Avid ISIS 5500 [view my complete system specs]
  • Mon, Apr 15 2019 2:19 PM In reply to
    • jcmcnamee
    • Brooklyn, NY
    • Posts 372
    • Points 3,990
    Other options are the Gain effect in Audiosuite or you can add an audio keyframe to the track and raise that an additional 1-12db.
    Media Composer 2022.12 / OS 13.1 / 27" iMac 5K 2017 [4.2 GHz Intel Core i7, 64 GB ram, Radeon Pro 580 8 GB] [view my complete system specs]
  • Mon, Apr 15 2019 3:14 PM In reply to
    • Erik
    • Joined on Thu, Oct 5 2006
    • Austin, TX
    • Posts 214
    • Points 2,525
    You can use the Audio Compressor effect in the Audio Suite but you'll need to do it to each track.
    The Audio Compressor can compress the dynamic range and is useful for raising the apparently loudness of the audio signal by raising lower parts of the signal while lowering the high parts acording to a ratio you set and a threshold level. There is gain knob here which will raise the signal.
    Experiment with it. It's much cleaner than just cranking the volume knob all the way up, which is generally just raising everything uniformally.
    MC 2019.9 Asus Prime X299 Deluxe, 64GB of Memory, Core i9 7940x @3.1Ghz, Nvidia GeForce GTX 1070 Ti. Running Win10 Pro 64bit MC 2018.4 Dell Precision... [view my complete system specs]
  • Mon, Apr 15 2019 3:30 PM In reply to
    Happens all the time. Sound recordists are sometimes a bit too careful. The simplest solution (ie without using audiosuite plugins, that can be dangerous) is to double the tracks.
    Reduce your Master output back to 0db (that way you wont have to greatly reduce the volume of your music and sfx tracks), then double each of the problematic tracks (eg copy and paste). Make sure they're not too loud now.
    That's it.
    Edit 1: MC 8.10 + Symphony + PhraseFind • MacPro 6x3.5GHz/64GB OS10.10.5 • Artist Mix & Color • Aja Io 4K • Edit 2: MC 8.10 • MacPro 2x2.66GHz/48GB... [view my complete system specs]
    Rodney Sewell BFS
  • Mon, Apr 15 2019 3:40 PM In reply to
    Normalize in Audio Suite is another option, although I don't like it as much as the Normalize effect in a dedicated audio program like SoundForge.   Another solution is to raise the volume on the low track to +12 and then do an audio mixdown of just that track and cut it into your sequence replacing the original low track.   Now you are starting at 0 on the mixdown and can raise it up to 12 again.
    MC 2018.12.3 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system... [view my complete system specs]
