Latest post Mon, Apr 8 2019 1:38 PM by Terry Snyder. 20 replies.
  • Mon, Apr 1 2019 6:47 PM
    Effect on Top (Graphic) Layer Only
    I put an alpha channel graphic on V2 on top of a video clip on V1.   I want to add a transition (spin, swish pan, etc.) at the head of the graphic on V2 to animate the way the graphic comes onto the screen.   However, the effect also effects the bottom video layer.   I only want it to effect the graphic on V2.    Is there a way to make this work?   Thanks.
    MC 2018.12.3 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system... [view my complete system specs]
  • Mon, Apr 1 2019 6:58 PM In reply to
    Re: Effect on Top (Graphic) Layer Only
    I just discovered that some transitions like Avid PlasmaWipe work without effecting the video layer below while other Avid effects like "spin" or many Boris transitions effect the bottom video layer when applied to an alpha channel graphic on the layer above. Confused
  • Sat, Apr 6 2019 3:59 PM In reply to
    Bump.  Anybody?
  • Sat, Apr 6 2019 7:22 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,969
    • Points 50,650
    • Moderator: MCA Mac
    I'm not sure that you can achieve what you want without doing an intermediary mixdown. The problem is that effects like Spin work on the entire video chain (all levels beneath the one where the effect is applied).
    Dave S.
  • Sat, Apr 6 2019 7:37 PM In reply to
    Terry Snyder:
    Bump.  Anybody?
    I did a rare deep dive a while back and then posted some tutorials for Avid-only (non-Boris) Effects solutions, so I would remember them...
    what you seem to be asking *might* be helped by this one:
    http://community.avid.com/forums/t/184062.aspx
    -Telegram!
  • Sat, Apr 6 2019 10:07 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,970
    • Points 70,575
    Hi Terry, have a look here http://community.avid.com/forums/t/79576.aspx for a video on a similiar question. You can accomplish what You want, but it's tricky. You should have old fashioned graphics with a real B&W matte, rather than a bitmap with alpha. You can roll Your own anyway: lay down the graphic file on the timeline as V1, apply the desired transition, step into the bitmap, copy the matte track, paste it to the timeline, apply the same transition; make two videomixdowns for both the "transitioned" bitmap and matte, now, assuming the background video is V1, cut the bitmap videomixdown on V2, and the matte videomixdown on V3, apply a matte key from the effect palette on V3 (You may need to invert the key in the effect editor). You can work out how to use variations on this trick to accomodate different needs, the key is to matte key (!) creating the required invredients.
    Symphony 24.12, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro T400 [view my complete system specs]
    peace luca
  • Sun, Apr 7 2019 6:32 PM In reply to
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 653
    • Points 8,270
    Terry Snyder:
    This is something Avid really needs to figure out and work on. You shouldn't have to go through major workarounds to stop a animation from affecting lower tracks.
  • Sun, Apr 7 2019 8:06 PM In reply to
    dew:
    Terry Snyder:
    Agreed, this comes up all the time and ought to work more intuitively.
    On the other hand, I just tried that recipe from my link above and it easily worked to stop a Spinning FX on a V2 alpha from affecting image on a V1 layer.
    -Telegram!
  • Sun, Apr 7 2019 8:37 PM In reply to
    If you step in and apply the effect in there it might do the trick for you.
  • Mon, Apr 8 2019 12:37 AM In reply to
    Telegram!:
    It never occured to me to promote the graphic to 3D Warp and move the effect around that way.  I think that would work.
    Thanks.
  • Mon, Apr 8 2019 12:46 AM In reply to
    Robert Goodman :
    I will give this a try as well.   I see these effects applied to titles and graphics all the time, so there must be an easy way to do it.  Maybe they are using specialized titling software with the transition effects already built in?
  • Mon, Apr 8 2019 12:47 AM In reply to
    DStone:
    If I do a mixdown, won't the top and bottom layers both be effected?   Or if I just mix down the alpha layer without the bottom layer, will it still have a transparency?   There's something I'm missing in figuring this all out.Embarrassed
  • Mon, Apr 8 2019 1:48 AM In reply to
    Just follow the instructions in my posted link above, it just works.
    Spectramatte is a trip and according to the Advabced Effects guide, superior to regular ChronaKey and RGBkeyer.  to http://resources.avid.com/SupportFiles/attach/AdvancedFXGuide_4.0_8.0.pdf#page231
    All you need is a solid color Blue or green masterclip. It’s a simple recipe.
    if there’s an easier way, I want to hear about it!
    -I could not get the submaster idea to work, btw.
    —I’m not sure I want to do a pair of video mixdowns, plus eventually somehow archive them, if that’s needed to do the Matte Key workaround, even if it looks somewhat cleaner. All this trouble for a transition effect on a alpha key...
    -Telegram!
  • Mon, Apr 8 2019 2:55 AM In reply to
    This post has been very helpful.  Thanks to everyone for the suggestions.
  • Mon, Apr 8 2019 4:58 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,970
    • Points 70,575
    Terry, turning the alpha bitmap into a matte key leads to a cleaner result than turning it into a chroma key.
    peace luca
