Latest post Fri, Feb 4 2022 3:50 AM by Dave Avid PM. 187 replies.
Page 11 of 13 (188 items) « First ... < Previous 9 10 11 12 13 Next >
  • Wed, Sep 2 2020 10:40 AM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,454
    • Points 16,005
    Re: Avid Titler+ - The good, the not-so-good and the ugly...
    Hello everyone,
    My next attempt Title +… 2020.08
    I managed to create static subtitles as laid out as in Marque.
    However, the response to the required actions at work, on my system in the HD25p project, is tragic.
    One layer in the produced caption began to move uncontrollably in the horizontal direction, no key points for movement were found, tracking turned off. He had to recreate the layer (this error was also transmitted during copying).
    An MC crashed while trying to select a caption color with the eyedropper.
    The color selection palette disappears into the background below the MC if you click elsewhere in the MC.
    It's really not "Save curent parameters as…", only defoult!?, I usually create preferences in Marque for individual projects and types of subtitles.
    The zero values ​​Translate (Layer (text)) are based on the position where you started typing. Center placement can only be estimated…
    One of the Layer 6 text does not appear in the timeline after closing Title + editing. (has a different text color than other Layers)
    Editing text (graphic and text) in a credit roll is practically impossible.
    V.
    AVID MC2019.11, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 441.28, RAM 48GB - DDR3, BM Intensity Pro 4k - 12.4.1, W10 - 64bit Professional... [view my complete system specs]
  • Wed, Sep 2 2020 2:27 PM In reply to
    I had a case going about the colour picker. I think it's fixed in 2020.8 on Mac. They know that the origin thing needs addressing. What version are you on?
    iMac i5 27", 40GB RAM, OS 13.7 with MC 2024.10 with Symphony option, BlackMagic 4K. 2020 MacBook Air with MC 2022.7 ... and NewsCutter 7.x on Dell... [view my complete system specs]
    ACI, Dorset, UK. www.avid-companion.co.uk
  • Wed, Sep 2 2020 4:18 PM In reply to
    • Vilem
    • Prague
    • Posts 1,454
    • Points 16,005
    Roger Shufflebottom:
    I tested 2020.08 in W10.
  • Fri, Jan 22 2021 7:33 PM In reply to
    • Susi
    • London, UK
    • Posts 609
    • Points 7,105
    Hello all - my first time without the old Title tool, and I can't see how to start making a title with the new setup.
    Is there a tutorial somewhere?
    Thanks for any tips
    Susi
    MCversion 2020-10-0 on macOS 10.14.6 13" early-2015 Macbook Pro; 3.1GHz Intel Core i7, 16GB 1867 MHz DDR3 Intel Iris Graphics 6100 1536 MB [view my complete system specs]
  • Fri, Jan 22 2021 7:40 PM In reply to
    Try this: https://vimeo.com/433695839
    And buy my book : www.avid-companion.co.uk !
    Roger S (edited!)
  • Fri, Jan 22 2021 8:24 PM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 303
    • Points 3,605
    Hi Roger,
    The link to your new book "The Media Composer Companion" is not working. You have to replace the dot between avid and companion with a hyphen. Wink
    https://www.avid-companion.co.uk is the correct link
    [AVID 1] HP Z840 | 2x 18 Core Intel Xeon E5-2699v3 / 2.3GHz 35MB | 128GB PC4-17000P 2133MHz / 8x 16GB DDR4 | NVIDIA Quadro P4000 / 8GB GDDR5 / 4x DP 5K... [view my complete system specs]
  • Sat, Jan 23 2021 10:09 AM In reply to
    Thanks - of course! I must think before I type :-(.
  • Sat, Jan 23 2021 10:31 AM In reply to
    • Susi
    • London, UK
    • Posts 609
    • Points 7,105
    Anyone feeling helpful? (Vimeo link got me nowhere, either, even when signed in)
    Seriously, just a link to a tutorial now that file>title tool ain't there any more
    Stay well everyone
  • Sat, Jan 23 2021 10:39 AM In reply to
    Forgive me - please try this link which should work:
    R
  • Sat, Jan 23 2021 10:51 AM In reply to
    • Susi
    • London, UK
    • Posts 609
    • Points 7,105
    Thank you so much!
    (Searching the 'tips and tutorials' on this webpage was a big mistake, and very demoralising)
  • Sat, Jan 23 2021 5:30 PM In reply to
    Susi:
    Thanks for any tips
    Here's my workflow for moving from the reliable old Title Tool to the "new and improved" Titler+:
    Step 1) Pour yourself a stiff drink.
    Step 2) Make sure the editing room is clear of children, members of the clergy, or other sensitive ears easily offended by displays of profanity.
    Step 3) Remove any items that can be used as projectiles causing damage to your monitor and secure sharp objects that can cause bodily harm.
    Step 4) Pour yourself another drink.  (Preferably a double.)
    Step 5) Create the title in Photoshop or another graphics program.
    Step 6) When in doubt, repeat Steps 1 and 4
    MC 2018.12.3 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system... [view my complete system specs]
  • Sat, Jan 23 2021 5:39 PM In reply to
    Before this spins out of control.  Please make sure you update to the 2020.12 release.  There were a lot of improvements, guided and directed by user feedback that are in this release.
  • Sat, Jan 23 2021 6:15 PM In reply to
    True - there is even a Tracker - labelled 'No Tracker 1' that does not do anything. The engineers do sometimes reveal a glimpse of the future for us ...
  • Fri, Feb 12 2021 8:33 PM In reply to
    • danny
    • Joined on Sun, Jan 24 2010
    • Posts 103
    • Points 1,225
    I'm afraid this is spinning out of control. I have worked on Avid since it's inception and regularly upgraded over the years, but have been stuck on MC 8.9.1 since the Titler+ saga. I recently decided to download MC 2021.2 on my second (Mojave) partition for testing and apraisal. Whilst the Titler+ is an improvement on the previous iterations, I have now come across a MAJOR issue regarding using Boris FX on the Titler+, which is a deal breaker on many fronts.
    My workflow has always used Boris FX on titles and I had hoped to continue. For now I am still able to use OS Mojave so have access to the old title tool, so I was able to compare what's going on between the two title tools. I can say that Boris FX still applies OK to the old title tool (apply to alpha channel). However, I cannot get any Boris filters to stick to any title made in Titler+. Maybe there's a secret workaround... There must be a way, I thought. It would seem not.
    I have written to Boris FX, who confirmed my fears, quote "...Unfortunately, I believe this problem you are seeing is because the Avid Titler+ does not Support an Alpha Channel, for any Filter (not just BCC, but any other third-party, and possibly even Avid Native filters of a similar nature)... I believe this lack of Alpha support inherent in the Titler+ is the cause of this problem"
    If this is the case, it will become a major headache for me, and no doubt many others. OK, for now I could continue with the old title tool whilst still using Mojave - for as long as it's supported (because I need access to old title tool for legacy projects). Catalina or Big Sur precludes use the old title tool.
    I had hoped the Titler+ would by now at least/at last have addresssed the alpha channel compatibilty with FX plugins, but it's gone completely in the wrong direction. It means I won't be able to use Boris FX on titles in 4K projects. Maybe I'm missing something but as I see it, having paid for another year of Avid subscriptions, I still can't reliably upgrade Avid, Boris FX, Mac OS or Mac hardware.
    Please could this issue be raised as a major bug that needs addressing. If Avid say it's not a bug but a feature, I'm not sure I will be paying for any more subcriptions for software that I can't use. Most of the other bugs introduced in the last two years can be worked around, but there appears no way around this Titler+ alpha channel issue.
    Maybe Avid can liase with Boris FX to find a solution. As things are, I feel stuck in limbo land. Please someone tell me there is a way out of this mess - other than not using Avid, Boris or Apple in future.
    Mac 3Ghz 8-core cylinder Xeon E5. 32GB 1866Mhz DDR3. AMD D700 graphics x2. OS 10.12.6 with MC/Symphony 8.9.1 and 10.14.6 with MC2020 [view my complete system specs]
  • Sat, May 8 2021 11:29 AM In reply to
    I just tried Titler+ again, but every few time I try to re-edit the title, its completely gone. I cant do anything to get it back, the effect is still on the timeline and monitoring for the video track is selected but I can only see the video without the title in the monitor window. And its VERY slow.. its rendering for ages just to create a simple text without any effects.. Any solution?
    I am editing on a very old macbook pro / mid 2012 with 16 GB ram Using macOS Catalina 10.15.7 And usually the newest AVID Version / right now its 2020... [view my complete system specs]
