Latest post Sat, Jan 20 2024 6:28 PM by Adman. 10 replies.
Page 1 of 1 (11 items)
  • Sat, Oct 20 2018 6:15 PM
    • dmabry
    • Joined on Thu, Dec 4 2014
    • Posts 7
    • Points 95
    Error Initialising bin Indexer Unable to set root path: /
    I have recently updated MC (after uninstalling everything and restarting), then installed new version and every project I open has this error message: Error Initialising bin Indexer Unable to set root path: /
    Is this a drive permissions issue? It doesn't affect my other computer at all (running the same version of the software).
    Running El Capitan and was on 8.5, but tried installing 2018.9 and 8.9 and both have same message, so it seems as though it's the Mac blocking something rather than MC?
    Any suggestions welcome!
  • Mon, Oct 22 2018 3:02 PM In reply to
    Re: Error Initialising bin Indexer Unable to set root path: /
    Did you install MC under and are you ruunning it under an administrator account?
    Where do your Avid projects live?
  • Mon, Oct 22 2018 3:10 PM In reply to
    • dmabry
    • Posts 7
    • Points 95
    Hi Kevin,
    Yes, it was installed (and runs) under an administrator account.
    The Avid projects are in Shared Projects within the Shared Users folder.
    My previous version of MC had none of these issues, but in updating to 2018.9, I had to reinstall the licence and wonder if something like that could contribute?
  • Wed, Oct 24 2018 2:06 PM In reply to
    Maybe...I'm wondering if you should try uninstalling / reinstalling once to see if that fixes it.
  • Tue, Mar 3 2020 4:38 AM In reply to
    Was there a fix for this in the end? I have the same issue with a machine.
    A selection of iMacs and some trashcan mac pros. [view my complete system specs]
  • Tue, Mar 3 2020 2:24 PM In reply to
    • dmabry
    • Posts 7
    • Points 95
    Hi Phil, the issue in the end for me was a conflict between Mac OS and permissions. I wasn't able to fix this without wiping the drive and reinstalling Mac OS clean, then installing Avid. This solved the problem...
  • Thu, May 27 2021 6:23 PM In reply to
    Simple fix, but try deleting your bay folder in the project.
    Worked for me!
  • Thu, Jul 22 2021 11:50 AM In reply to
    • mire
    • Joined on Tue, Nov 17 2015
    • Posts 1
    • Points 15
    Sorry for the stupid question - but.. what is the bay folder? Hmm
  • Thu, Jul 22 2021 5:43 PM In reply to
    • Marty McLean
    • Joined on Tue, Aug 16 2016
    • Sydney, NSW
    • Posts 200
    • Points 2,460
    • Moderator: MCA Mac
    Not a stupid question! Stick out tongue
    The 'bay folder' contains settings for each computer connected to the Nexis. Right now I'm on iMac4 so there is an 'iMac4' folder in my Bin Container/Project window.
    MC 2023.12.1 | Interplay 2023.7 | Z4 G5 [view my complete system specs]
  • Sat, Apr 22 2023 3:27 AM In reply to
    • binba
    • Joined on Mon, Jan 15 2007
    • Posts 95
    • Points 1,325
    This is indeed a permissions issue, and one that can still happen now, 5 years later. (Hence keeping the thread.)
    As Apple keeps increasing their OS's security, there are actually more opportunities to run into this.
    In my case, the cause was working on the Nexis, and someone didn't "Allow" the dialogue window to approve Media Composer to access network volumes. It was unchecked in System Preferences > Security > Privacy > File Access. Checking that box fixed it... no need to wipe the computer.
  • Sat, Jan 20 2024 6:28 PM In reply to
    • Adman
    • Atlanta Georgia, USA
    • Posts 5,522
    • Points 62,595
    • BlogAuthor
    Fwiw, I've had this nagging issue and finally got around to fixng it simply by allowing AvidBinIndexer to access data in the Security & Privacy section in preferences on the Mac. :)
    Mac Pro, Monterey, 64GB Ram. 1TB SSD system drive, 250Gb SSD external (media) drive. QHD Ultra wide, thunderbolt LG monitor, MC 2021.12 Pro Tools 2021... [view my complete system specs]
