Latest post Sun, Jun 30 2019 11:28 PM by anita96. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Oct 4 2018 3:57 PM
    AMA Plug-in Error
    I am trying to open a sequence I created a few years ago and keep getting this error whenever I try to play it:
    "Exception: Failed to get sample position from the AMA plug-in"
    When I originally created the sequence, I consolidated the shots to DNxHD and deleted the AMA version of the clips.  I can Match Frame to the shots and they are there--I can play them and cut them in to a new sequence.  I have checked every bin in the project and there no AMA linked clips.
    MC 2018.12.3 with Symphony, Matrox MX02 Mini Max, Win 7 Pro, HP Z800 2x6-Core 3.2Ghz Xeon, 48GB ram, Quadro K4200, SanDisk Extreme 240GB SSD as system... [view my complete system specs]
  • Thu, Oct 4 2018 4:22 PM In reply to
    • Posts 11,887
    • Points 259,660
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    Re: AMA Plug-in Error
    Hi Terry
    I 'd check that the original files on the disk are Ok and NOT corrupt.
    Play using a third party player such as VLC.
    If the media file itself is corrupt you'll need to restore it from a backup. If it checks out, try copying the file to a new drive, hiding the original from Avid and re-linking it. Note that sometimes links separate media files in to a single file (XDCAM for example will string multiple 2G files together) that can also cause this.
    If that isnt it then I suggest you contact support and have a tech check your computer and MC out.
    Sr. Director | Customer Experience and Community [view my complete system specs]
  • Thu, Oct 4 2018 4:38 PM In reply to
    Hi Marianna,
    The weird thing is the clips play fine in the bin and I can cut them into a new sequence.   When I click the monitor on the top track  (a video mixdown) I can play the sequence, but selecting the monitor for any other video tracks (even tracks not containing clips such as titles, etc.) gives the error and the sequence won't play.
  • Thu, Oct 4 2018 4:43 PM In reply to
    I checked all the bins in this project and don't have any AMA linked clips.  Is there a way to force a "break" to any AMA link that is hiding somewhere and interfering with the playback?
  • Thu, Oct 4 2018 9:14 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,454
    • Points 16,005
    Hello,
    I would try to view the colors of the clip in the timeline and tick the AMA.
    Next, I would try to cut the sequence into a new sequence (not duplication, create a new sequence and then cut off the original sequence).
    V.
    AVID MC2019.11, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 441.28, RAM 48GB - DDR3, BM Intensity Pro 4k - 12.4.1, W10 - 64bit Professional... [view my complete system specs]
  • Thu, Oct 4 2018 9:21 PM In reply to
    Vilem:
    Not sure what you mean?   Open up color correction?
    Vilem:
    I did that and I still get the error.
  • Fri, Oct 5 2018 6:19 AM In reply to
    • Vilem
    • Prague
    • Posts 1,454
    • Points 16,005
    Terry Snyder:
    Vilem:
    Quick menu at the bottom left of the timeline, "Clip color", see the attached picture.
    I would also try to consolidate the sequence with the "Consolidate only linked media"
    V.
  • Sat, Oct 20 2018 5:32 PM In reply to
    Vilem:
    Thanks.  I was able to find the clips that were AMA linked to footage no longer available.  After deleting these from the timeline, I was able to play the sequence.
    On future versions of MC, it would be great if MC would still play the sequence but simply display a black screen with the words "AMA clip off line" (or something to that effect) the same way it gives a "Media Offline" message but still keeps playing.   As it stands now, if there is a single broken AMA link in a sequence, MC won't play the sequence at all and displays the "Failed to get sample position from the AMA plugin" error.
  • Sun, Jun 30 2019 11:28 PM In reply to
    • anita96
    • Joined on Thu, Dec 10 2015
    • Posts 35
    • Points 495
    Hi there,
    I also thave this problem now. A whole sequence, ll the sequences in this project, EVERYTHING, I cannot play it back. all has gone offline too, cannotr be linked or touched anyway. I still have been workling on it today, now the whole project ist unusable. I evene deleted the AMA management folder, as it has been sugested on a different forum, but no success. another project, htat used to work too, I cannot even export it. Everything I hve been working until now, is inaccessible. Also MC has started to crash with every move I do. Many days of work is destroyed and as I am in a hurry, i need to thing about going over to a different softwar, maybe having to purchase Adobe Cloud. and redo the whol lot again. Can't even imagine, what a mess this is.
    PLEASE HELP!!!!
    I worl on a Mac Min 16GB Memory, used to work allright, everything till now. And that happened on a  other proeject in a earlier version before, but not for whiole, unti lnow. And why cannot i not export same a source? What is Long GOP? thannks, Anita
    Thanks you, Anita
