Latest post Thu, Nov 14 2019 3:06 AM by jef. 4 replies.
  • Wed, Oct 3 2018 9:24 AM
    • Rory T
    • Joined on Wed, Mar 21 2018
    • Posts 64
    • Points 755
    Export Custom Videos with 12 tracks of Audio
    Hello all,
    I always thought that to get more that two discrete tracks of audio from an export you had to export 'same as source' and then flip it into your desired format in a third party application.  Or alternativly, mixdown to the
    your desired format and then export 'same as source'.
    I recently discovered, through forums here, that using the 'audioextras' command direct out was now a selectable option in 'custom' videos.  A 5.1 LRCLfeLsRs (selected in the sound settings, in the format options of the custom video) can now be created.  But what about true direct out.  Ten or 12 tracks of audio mapped 1 to 1, 2 to 2 etc.  Ideally it would be stereo mix 1-2, MNE 3-4, LRCLfeLsRs 5-10.  Is this possible?  Any help is greatly appreciated.
    Regards,
    Rory
  • Wed, Nov 13 2019 4:04 PM In reply to
    • Rory T
    • Posts 64
    • Points 755
    Re: Export Custom Videos with 12 tracks of Audio
  • Wed, Nov 13 2019 4:18 PM In reply to
    • Rory T
    • Posts 64
    • Points 755
    Is this doable?  There really is a potential to half the workload for certain projects if you could export direct out audio as a non-same-as-source file.
  • Wed, Nov 13 2019 5:30 PM In reply to
    • Rory T
    • Posts 64
    • Points 755
    Is this doable?  It would cut the export times in half if you could export non-same-as-source files with direct out audio.
  • Thu, Nov 14 2019 3:06 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,868
    • Points 46,705
    I would read and experiment with the following:
    http://24p.com/wordpress/?p=278
    It is the most efficent way to export I believe.
    Jef
    Jef Huey
