Latest post Fri, Jun 8 2018 10:01 PM by studiosanctum. 3 replies.
  • Mon, May 28 2018 5:40 PM
    MC Fullscreen mode does NOT work when...
    MC Fullscreen mode does NOT work when you are using a second display and have it arranged on top of your main display. Insane bug that I cannot believe Avid has let linger for years.
  • Tue, May 29 2018 2:07 PM In reply to
    Re: MC Fullscreen mode does NOT work when...
    Avid technical support sent me this:
    ”I have checked the records in here that is tied up with the vertical monitor and was found out that it was actually an unsupported set-up that is why this has not worked before and now. The qualified configuration is a side to side set-up. However, a feature request has already been submitted to Engineering and it is up to them when they would integrate this feature.”
    Seriously?
    How hard can this be?
  • Tue, May 29 2018 8:51 PM In reply to
    Since you're working full screen on the top monitor, would a reasonable (though admittedly iirritating) workaround be to arrange it in the system setup to the side of the main dispaly?
    Edit 1: MC 8.10 + Symphony + PhraseFind • MacPro 6x3.5GHz/64GB OS10.10.5 • Artist Mix & Color • Aja Io 4K • Edit 2: MC 8.10 • MacPro 2x2.66GHz/48GB... [view my complete system specs]
    Rodney Sewell BFS
  • Fri, Jun 8 2018 10:01 PM In reply to
    Why can't they make arranging your screens stacked on top of eachother work?
