Latest post Wed, May 23 2018 4:38 PM by Marianna. 5 replies.
Page 1 of 1 (6 items)
  • Sun, May 20 2018 8:39 PM
    • John Mac
    • Posts 184
    • Points 2,465
    iZotope Insight causes Avid to crash
    Hi all
    anyone experience constant crashing when trying to use iZoptope Insight? I am bang up to date with Avid and want to trial this plugin but everytime I try to open it, it causes Avid to crash.
    John
    MC 8 Windows 7 Pro 64-bit i7 Intel Core 4 cores 3.5 GHz 16 Gb ram Nvidia quadro 4000 Matrox mini 6TB internal connected to SATA III ports [view my complete system specs]
  • Mon, May 21 2018 3:56 PM In reply to
    • Posts 11,575
    • Points 255,625
    Re: iZotope Insight causes Avid to crash
    John
    Might be a conflict between that plug in and another you have.
    Are you able to pull the plug in folder to your desktop.  Make a copy of it.  take all the stuff out of it except the iZoptope Insight and put the folder back and remain it to remove the copy.   see if it works.  If it does then there is a conflcit.
  • Mon, May 21 2018 5:34 PM In reply to
    • John Mac
    • Posts 184
    • Points 2,465
    HI Marianna
    I have looked for Insight in plugins but it only appears in iZotope folder within Program Files (x86)
    Cannot seem to find audio suite plugins in a plugin folder
    John
  • Mon, May 21 2018 5:44 PM In reply to
    • Posts 11,575
    • Points 255,625
    John
    Your using MC | First so.... only the plug-ins that you buy from the Market place will work.  Where did you get that plug-in JOhn?
  • Mon, May 21 2018 6:36 PM In reply to
    • John Mac
    • Posts 184
    • Points 2,465
    HI Marianna, iZotope Insight is already with MC on a 30-day trial so it's preloaded loaded as part of audio suite
    I do however have iZotope RX5 which I purchased
    John
  • Wed, May 23 2018 4:38 PM In reply to
    • Posts 11,575
    • Points 255,625
    John
    Unless you purchased that from the Marketplace for MC First, you cant use it.
    For Mac OS X:
    1. Navigate to Macintosh HD > Library > Application support > Avid
    2. Move the AVX2 folder somewhere safe. (preferably the desktop)
    For Windows:
    1. C:\Program Files\Avid\AVX2_Plug-ins
    2. Move the AVX2 folder somewhere safe.(preferably the desktop)
    Several known plug in's cause the issue.
      phaser.aaxplugin
    Waves v9
    iZRX6DeclickerAAXHook.aaxplugin
    iZRX6DeclipperAAXHook.aaxplugin
    Vibe Phaser.aaxplugin, dated Jan 14, 2016 Vibe Phaser.aaxplugin, dated Jan 14, 2016
    AIRVintageFilter.aaxplugin, dated Feb 19, 2015
    AIRReverb.aaxplugin
    AIRSpringReverb.aaxplugin
    AIRStereoWidth.aaxplugin
    AIRTalkbox.aaxplugin
    Absynth 5 (Native Instruments)
    FM8 (Native Instruments)
    Guitar Rig 5 (Native Instruments)
    iZNeutrino (iZotope)
    iZOzone 7 (iZotope)
    iZVinyl (iZotope)
    Kontakt 5 (Native Instruments)
    LEVELS (Mastering the Mix)
    Massive (Native Instruments)
    Reaktor 6 (Native Instruments)
    REFERENCE (Mastering the Mix)
    Replika (Native Instruments)
    Transient Master (Native Instruments)
    WaveShell 9.7 (Waves)
    WaveShell 9.91 (Waves) HTH
