Latest post Mon, May 7 2018 10:12 PM by ZFigas. 11 replies.
Page 1 of 1 (12 items)
  • Sun, May 6 2018 10:55 PM
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Any tricks to setting up Media Composer 2018.4 with an UHD Monitor?
    Hi folks - been thinking about upgrading my monitor from two old 22" displays to a single 32" 4K display and I wondered if there were any tricks to configuring MC in this case. I'm running the latest Windows 10 (not beta). Do we still need to configure compatibility of MC? Do you set the font scaling to 150%, etc. - I would like to have some idea and for some odd reason I've not been able to find much through a Google search (just loads of complaints from a time when MC really didn't support high DPI displays).
    Thanks in advance
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Mon, May 7 2018 12:55 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Re: Any tricks to setting up Media Composer 2018.4 with an UHD Monitor?
    Lots of views of this thread. Anyone using a single UHD monitor with Media Composer?
    Steve
  • Mon, May 7 2018 6:11 PM In reply to
    • CeeBee
    • Joined on Mon, Sep 5 2016
    • Posts 27
    • Points 335
    hello,
    i am using a philips 42" UHD Monitor - is realy a new working. If you have the space in your room i would suggest this. An yes its working without any problems.
    cheers
    c.
  • Mon, May 7 2018 7:43 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Thanks C. I guess with a 42" monitor you don't have to worry about fonts being too small - lol.
    Cheers
    Steve
  • Mon, May 7 2018 8:10 PM In reply to
    • ZFigas
    • Joined on Tue, Jan 31 2006
    • Poland
    • Posts 184
    • Points 2,390
    Only problems. Avid does not properly support the 4k monitor in Windows 10.
    Zbigniew
    HP Z8 G4, 2xXeon-6246R, 128 GB RAM, Win 11 Enterprise, MC 2021.12, Nvidia Quadro RTX 4000, Boris Red 5.6, BCC 14.03, Saphire 2021.02, Adobe CC, TMPGenc [view my complete system specs]
  • Mon, May 7 2018 8:42 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Really. So how do you suppose c. was able to get it working?
    Steve
  • Mon, May 7 2018 9:07 PM In reply to
    • ZFigas
    • Poland
    • Posts 184
    • Points 2,390
    I have 32” Eizo CG-318K.
    At the moment I resized Windows to 135% but it is not solution.
    Boris pugins - BCC and Saphire completely resize bad and everything is too small.
    But don’t worry Avid correct it in 2030, after landing on the Mars.
    i exactly know that problem lie not only in Avid but in Windows, also.
    Zbigniew
  • Mon, May 7 2018 9:14 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Are you running the latest Media Composer? 2018.4?
    Thanks for the feedback.
    I would very much like to hear from Avid on this because any threads I could find suggested that MC was now compatible with High DPI monitors...
    Cheers
    Steve
  • Mon, May 7 2018 9:40 PM In reply to
    • ZFigas
    • Poland
    • Posts 184
    • Points 2,390
    I will send few prtscr how looks Avid and Boris plugins, by email.
    Give me time.
    Regards
    Zbigniew
  • Mon, May 7 2018 9:50 PM In reply to
    • ZFigas
    • Poland
    • Posts 184
    • Points 2,390
    Of course, I have Windows 10 after Spring update, MC 2018.4 and newest Boris plugins.
    Generaly problem monitor 4K is not solved by Windows and by Avid and Boris.
    Zbigniew
  • Mon, May 7 2018 9:56 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    I was told that you have to set the Windows scaling to 200% - have you tried that?
    Thanks again for the feedback -
    Cheers
    Steve
  • Mon, May 7 2018 10:12 PM In reply to
    • ZFigas
    • Poland
    • Posts 184
    • Points 2,390
    I bought super monitor 4K because I would like to have super quality. Resizing is half measures because fonts are blurred.
    Base question is what we want - big monitor or big monitor 4K. Cheaper is to buy monitor 32” but 2560x1440 and everything will be OK.
    i read suggestion that good solution is monitor 42”. Better is maybe 65”.
    Zbigniew
