Latest post Thu, Nov 9 2017 12:39 PM by Kevs999. 2 replies.
  • Wed, Nov 8 2017 10:24 AM
    • Kevs999
    • Joined on Mon, Jul 18 2016
    • Posts 58
    • Points 820
    field render issue on long sequence render
    We have some odd render issues on a couple of clips within a 2 hour timeline sequence on Media composer 8.9.1.
    When we render the entire sequence to avid DnxHD 120i these clips exhibit parts of the picture moved sideways on one field, this over a second or so.
    However when you render just the affected section the error is not there, indeed if I render the timeline in 4 half hour chunks again the problem does not show, but once again output the entire 2 hours and the problem shows up. It's not in random places but always the same point, but as I say never when you render shorter chunks.
    Any suggestions ?
    Media Composer 8.9.1
    Windows 10 Professional
    Z420
    i7-5930K Windows 10 Professional 64 bit 32GB RAM GTX 970 AJA Kona LHE Plus I/O Internal 7TB Raid [view my complete system specs]
  • Thu, Nov 9 2017 3:10 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,184
    • Points 50,475
    Re: field render issue on long sequence render
    What is the ultimate goal?
    Are you doing a mixdown or just renders?
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2023.3.1 iMac w Big Sur and 2018.12.7 on Windows 10 Boot Camp [view my complete system specs]
    Jef Huey
  • Thu, Nov 9 2017 12:39 PM In reply to
    • Kevs999
    • Posts 58
    • Points 820
    Wanting to output the finished programme as a Mixed down file in avid dnxHD to hand on to someone else.
    Never had this issue in the past so it could be something to do with those bits of media, or the place where they are stored or an issue with this particular version of media composer.
    Just backing up all our projects etc and then will upgrade to latest version and see if problem persisits.
    I have also consolidated the timeline to a new drive and will try to produce an output file from that again to see if the issue remains.
