Latest post Tue, Oct 3 2017 10:13 AM by Keith R. 85 replies.
Page 4 of 6 (86 items) « First ... < Previous 2 3 4 5 6 Next >
  • Tue, Sep 12 2017 10:38 AM In reply to
    Re: Can't get into Media-First.
    Media Composer is a 64bit application. You can't run it under windows 10 Pro 32 bit.
    That would be a major limitation!
    T 07581 201248 | E [email protected]
  • Tue, Sep 12 2017 11:24 AM In reply to
    • Keith R
    • Joined on Fri, Jun 8 2012
    • Posts 286
    • Points 3,405
    Pat Horridge:
    Apol -  quite correct,  we overlooked this limitation simply because  people were talking about running on old hardware, we have people talking about going back a long way we  assumed incorrectrly ..
    Thanks again people,  Drawing on our  own experience only we are well under the required minimum specification for MCF thanks again ...
    Regards
    Keith A
  • Tue, Sep 12 2017 12:14 PM In reply to
    Windows 7 is still supported and that has been available as 64 bit since around 2009 so 17 years...
    You do need a 64bit processor etc of course.
    But to be honest if you are looking for a solution for video editing using modern source files (HD H264) then you need hardware thats 5 years old max I'd say. Ideally 3 years old or less and in a perfect world the model yet to be released !
  • Thu, Sep 14 2017 1:26 PM In reply to
    • Keith R
    • Posts 286
    • Points 3,405
    Pat Horridge:
    Hello Pat
    Agree completely - also just tried it on Windows 7 Professional 64 bit ..
    Just found another limitation :-
    Error Messsage:- Your system does nor support this version of Media Composer ..
    Has anyone had any issue with Windows 7 Professional 64 bit .. ?
    Regards
    Keith A
  • Thu, Sep 14 2017 1:40 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,932
    • Points 32,390
    Keith R:
    I'm on Window 7 64 bit desktop and laptop both running i7. What is the processor of your Windows 7 machine?
    RalphC
    MacBook Pro 15 2018 Intel Core i7 2.6GHz Mac 10.15.7 Intel UHD 630. [view my complete system specs]
  • Thu, Sep 14 2017 2:44 PM In reply to
    • Keith R
    • Posts 286
    • Points 3,405
     Hi Ralph
    Spot on good question , we were  trying to find a low spec solution so on your advice  Windows 7 Professional 64 bit should be OK however :-On  processore we have experimented with  LGA 775 Dual and Quad so yes - not supported it seems ..Have now experimented with good i7 machines down to would you believe Pentium E2200
    In conclusion we don't have anything that supports it and thanks to all once again
    cheers
    Regards
    Fred
    For Keith A
    Thanks again
  • Thu, Sep 14 2017 5:26 PM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 570
    • Points 7,805
    No. In fact, I upgraded to 8.9.1 and it is more screwed up than before. App Manager disappeared, can't find it. Now its back to opening MC First,  but no buttons work, only the chirp sound. I have to quit using Task Manager. This is a mess!! How do I re-download App Manager so I can  get MC First to open and work? Not thrilled. Laptop has 8gigs of RAM and a i5 quad-core processor, which all worked fine before the "upgrade". Any help here?
  • Thu, Sep 14 2017 6:10 PM In reply to
    • Posts 12,141
    • Points 262,325
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    Bushfilm
    I am going to suggest I create a case and have support assist - however if you dont want to wait for them....  I suggest the following..... ( let me know if you want me to create  case)
    Do a get info on Appman and see if you are running AppMan v17.8.
    I would then Uninstall MC | First completely ( this would be version 8.9.1).  Then I would download it again and I can provide you with the direct link.  Just need to know Mac or PC.
    Sr. Director | Customer Experience and Community [view my complete system specs]
  • Thu, Sep 14 2017 8:35 PM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 570
    • Points 7,805
    I re-downloaded the program after upgrading to 8.9.1 after which everything went to hell. Now I can't open the program with App Manager or directly by clicking on it. I had created two projects which are now gone. This is a mess! What do I need to do to use this program? I don't know what a root directory is so please explain in detail. Shouldn't be this HARD!
  • Thu, Sep 14 2017 9:44 PM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 570
    • Points 7,805
    So now I made the mistake of upgrading to 8.9.1 and now nothing works. I can't open from the desktop icon or from App Manager. It worked before upgrade but only if you opened it from App Manager, otherwise, only an edit page that didn't work, buttons only chirped and the edit page took up full screen and you can't resize it, in case there is something going on behind it. Not very happy camper. I realize its free, but c'mon Avid, you could've tested this better. Now I am going to try to use the footage I imported in "First" in my old reliable Media Composer, but not sure how to re-link the footage. Should I create a new project with the same name, then throw away the id file in Avid Media folder so that a new path will be created in MC? What a headache this has been! Thanks to anyone who can help.
  • Thu, Sep 14 2017 9:51 PM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 570
    • Points 7,805
    Yes, app man is v17.8 and I did uninstall and re-install 8.9.1, still no joy. So feel free to open a case. I know its free, but it should work, no matter what it cost. I downloaded from the Avid site, so if you have a secret better direct link, by all means, please send it along. My laptop has 8 gigs of RAM, an i5 quad core processor, and Windows 7 Pro (64 bit). Thanks muchly!
  • Thu, Sep 14 2017 9:52 PM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 570
    • Points 7,805
    The above was for Marianna. Thanks, Marianna.
  • Thu, Sep 14 2017 11:51 PM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 570
    • Points 7,805
    I am running Media Composer- First on a Windows 7 pro 64 bit machine with 8 gigs of RAM and an i5 quad core processor.
  • Fri, Sep 15 2017 12:30 AM In reply to
    • bushfilm
    • Baton Rouge, LA
    • Posts 570
    • Points 7,805
    And if all the above wasn't enough, the link to the ProSound Effects library doesn't work either.
  • Fri, Sep 15 2017 6:14 AM In reply to
    • Keith R
    • Posts 286
    • Points 3,405
    bushfilm:
    Hello again
    With the very best of intention only and without otherwise in any way ..
    I started this thread and have to the best of our knowledge run with every suggested "fix"
    approx 30 hours in all to date ..
    conclusion .. we can't get into Media Composer First
    We will have to cool it for a while, we have no opinoin whatsoever as to the cause other than
    Regards
    Keith
