Latest post Thu, Jul 13 2017 6:06 PM by RalphC. 10 replies.
Page 1 of 1 (11 items)
  • Mon, Jul 10 2017 12:35 PM
    • Kevs999
    • Joined on Mon, Jul 18 2016
    • Posts 58
    • Points 820
    cant install media composer first
    Have downloaded Media Composer First for windows but no matter how I try to install it tells me there are files missing and doesnt complete the install process.
    I have tried on another machine with the same issue, all Windows 10.
    Any help appreciated.
    i7-5930K Windows 10 Professional 64 bit 32GB RAM GTX 970 AJA Kona LHE Plus I/O Internal 7TB Raid [view my complete system specs]
  • Mon, Jul 10 2017 2:02 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,969
    • Points 50,650
    • Moderator: MCA Mac
    Re: cant install media composer first
    Please unpack the installation into a top level directory (e.g. C:\) and then try.
    Dave S.
  • Mon, Jul 10 2017 2:59 PM In reply to
    • Kevs999
    • Posts 58
    • Points 820
    Will this not install on Windows 10 HOME version maybe ?
  • Mon, Jul 10 2017 6:10 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,969
    • Points 50,650
    It's not designed for W10 Home, but user have installed it on Home and it has worked. If you've not tried installing from the top level directory, please do so. There's a known issue where installing from a subdirectory may cause the install to fail.
    Dave S.
  • Tue, Jul 11 2017 12:55 AM In reply to
    I have the same problem and I installed using application manager.
    http://www.pro-tools-pc.com/ Running Windows 10 Home.
  • Tue, Jul 11 2017 1:22 PM In reply to
    • Posts 12,180
    • Points 262,750
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    Hey Bob
    MC | First was tested on Windows v7 64-bit SP1(Professional) and Windows v8.1 (Professional and Enterprise), Windows 10 64-bit (Professional and Enterprise).   It was not tested nor developed for any Home Editions. While some have gotten it to work, others havent.
    I am wondering if your system was previously on Win 7 or Win 8 32 bit prior and you upgraded to Win 10 Home?
    why I ask......  The free Windows 10 upgrade that came out through Windows Update (which is how most people received  the update),  does not have an option to choose Windows 10 32-bit or 64-bit; it will automatically default to your current operating system architecture.  So if you had 32 bit Win 7 and upgrded using the win 10 home free upgrade, then you are still at 32 bit.
    MC | First works on 64 bit only.
    Just a thought....
    Sr. Director | Customer Experience and Community [view my complete system specs]
  • Tue, Jul 11 2017 1:40 PM In reply to
    • DStone
    • Massachusetts
    • Posts 3,969
    • Points 50,650
    Marianna:
    Wow. There's a bit of info I never knew.
    Dave S.
  • Tue, Jul 11 2017 1:46 PM In reply to
    • Posts 12,180
    • Points 262,750
    • ! Avid Employee
      ForumsAdministrator
    Dave
    Me neither until I did a bunch of research yesterday when back from vacation. Wanted to catch up on some of the MC | First issues and found that little gem.
    This is why I think some work in Home and some dont.  Not that anyone should be using Home :)
  • Tue, Jul 11 2017 2:56 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,932
    • Points 32,390
    Kevs999:
    Does it say what are the files missing?
    RalphC
    MacBook Pro 15 2018 Intel Core i7 2.6GHz Mac 10.15.7 Intel UHD 630. [view my complete system specs]
  • Tue, Jul 11 2017 3:55 PM In reply to
    • Kevs999
    • Posts 58
    • Points 820
    I think it was all the dll's....but I have now managed to install the software correctly.
  • Thu, Jul 13 2017 6:06 PM In reply to
    • RalphC
    • Posts 2,932
    • Points 32,390
    Kevs999:
    How did you solved the installation issue? Please share to the group in case we run to this in the future.Thanks!
    RalphC
