Latest post Tue, Feb 18 2020 3:38 PM by Marianna. 14 replies.
Page 1 of 1 (15 items)
  • Wed, Jun 28 2017 12:41 AM
    • cls105
    • los angeles
    • Posts 544
    • Points 7,005
    Not enough space for transcode warning is false.
    MC 8.8.4 win 10
    Usually Im given a lot of 4k (not exactly sure of resolution) footage from Alexa.
    When I transcode I usually transcode to project resolution, usually 1080p 23.98
    And Ill select to source's frame rate and choose DNX SQ
    It will say that there isnt enough room which is completely false.  Is there a way to bypass this warning so it just transcodes to this drive regardless.  The calcuation doesnt seem to be acurate.
    and here's a feature request for transcoding.  It would be cool if Media Composer transcoded in alphabetical order, that way if there is an error, its very to easy to see where it left off, and resume.
    w10, always the latest version of MC, diy 7940x, gtx 1080 ti. [view my complete system specs]
  • Wed, Jun 28 2017 4:29 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,888
    • Points 69,780
    Re: Not enough space for transcode warning is false.
    cls105:
    You can try to transcode the clips in batches, instead of all at once; this could be a bit of a problem if You're an overnight transcode kind of person! And the false warning shouldn't pop up nevertheless, the editor should just work.
    Symphony 21.6, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Wed, Jun 28 2017 6:53 AM In reply to
    • cls105
    • los angeles
    • Posts 544
    • Points 7,005
    Yes that is one work around, another is background transcoding, or finding another drive.
    There are several work arounds, but I feel like it should be fixed.  thanks!
  • Wed, Jun 28 2017 7:23 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,888
    • Points 69,780
    cls105:
    You mean that it does work when background transcoding?
    cls105:
    I certainly do agree with that!
    cls105:
    thanks!
    My pleasure!!
    peace luca
  • Wed, Nov 21 2018 2:17 AM In reply to
    • cls105
    • los angeles
    • Posts 544
    • Points 7,005
    one year later... still a problem.
    on the bright side, at least I can
    Connect. Collaborate. Get Discovered.
    with avid link.
  • Wed, Aug 7 2019 2:49 PM In reply to
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Haverhill, MA
    • Posts 574
    • Points 6,645
    Do you know if this was ever resolved?
    -Matt M.
  • Fri, Feb 7 2020 5:35 PM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 1,192
    • Points 14,830
    I'm here now.  Not enough space to transcode a 34Gig file to a 16Tb stripe!!!!!!
    Symphony 2018.12.10, Blackmagic Intensity Pro 11.1 (unsatisfactory in full res UHD though for client monitor), WIN 10 on 2500Mbps M.2 SSD, Nvidia Quadro K4200, Asus X99-A Mobo, i7 5820K 4.0 GHz Hex core mildly overclocked CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10 array @ 450Mbs
  • Fri, Feb 7 2020 6:42 PM In reply to
    First off we are talking NTFS for all the drives involved aren't we?
    Also how much space on the boot drive? It maybe a tmp file issue.
  • Fri, Feb 7 2020 7:52 PM In reply to
    • DIESELE
    • Posts 1,192
    • Points 14,830
    Good call Pat but yes all NTFS.  C: has about 120Gb free as an SSD M2.
    I had to give up transcoding to a more multicam friendly intra frame codec - tried a few transcode settings inc background and and DNX120 and DNXHR SQ and also a timeline mixdown.  All baulked so I'm multicamming with this one C100 long gop source - all the other long GOP ones transcoded Ok - inc the 3 hour 'wide' cam.
    She's coping OK with 14 streans and one long GOP! Thank goodnes the 50P clip WOULD transcode to 25P as it was always out of sync.
  • Sun, Feb 9 2020 5:04 PM In reply to
    Here's a link to a post I made in May 2016 with the exact same issue. And even in May 2016 this was not a new issue, it had been going on for ages. It's very annoying. Luckily I work with a Nexis which allows me to increase the size of the workspace so that I can transcode, but I can imagine it is very annoying for people who aren't able to do this. Fix it Avid!
    Andi
    HP ZBook G6 15 2.6Ghz 6-core i7 9th Gen Nvidia Quadro T2000 4GB 64GB RAM Win 10 Pro MC Ultimate 2018.12.11 MacbookPro 15 2019 6 core 2.6GHz i9... [view my complete system specs]
  • Mon, Feb 10 2020 9:43 AM In reply to
    • DIESELE
    • Posts 1,192
    • Points 14,830
    Marianna - do you think this can be escalated - we have several with the issue.
    I tried all sorts to get my transcode to keep going without the 'failed to write essence' error - subclips, mixdowns, different codecs, different drives (all with plenty of space) but it just would not do it.
  • Mon, Feb 10 2020 2:45 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,645
    Some details from when I've seen this that could maybe be helpful.
    We start with a number of XAVC Intra clips and are transcoding to DNxHR LB
    On the Transcode screen the size estimation shows as 182429 MB. When running the transcode it hangs for a little bit then throws an error stating there is not enough space indicating that the transcode needs 1.8TB of space.
    Workarounds are to run a background transcode or to do the transcode in smaller chunks.
    Once you get the transcode to go through bby either of these methods and add up the file size it matches the smaller ~182 GB size.
    Seems like there is some bad math somewhere...
    -Matt M.
  • Mon, Feb 17 2020 6:26 PM In reply to
    • mmullen
    • Haverhill, MA
    • Posts 574
    • Points 6,645
    I was able to track down a reporducible case for this.
    Create a new 1080 59.94 project.
    Link to media of another frame rate.  In my case I have a 25fps pro res QT.
    Open the transcode screen and make sure to select Keep Source's frame rate.
    Note the space required and select a destination that only has 1.5 to 3 times the required space for the transcode.
    Choose transcode and see the error.
    -Matt M.
  • Mon, Feb 17 2020 6:42 PM In reply to
    • DIESELE
    • Posts 1,192
    • Points 14,830
    Just pinged Marianna to the thread - I'm sure she will flag this up appropriate given tghe great info on a concrete way to reproduce it.  Thanks
  • Tue, Feb 18 2020 3:38 PM In reply to
    • Posts 11,562
    • Points 255,350
    Diesele et al....
    got this one and will create case ( Case # 03886366 ) and get it escalated.  Apologies but took the weekend off for my birthday Smile
