Hi I have a client desperate to change default file location for either Avid Projects or Attic backup. Is this possible on a Mac? Thank you
John M
You would use "External" from the Select project folder and navigate to the folder you would use.
"Private" goes to your home folder, "Shared" goes to your Shared folder.
And I believe the Attic will follow your selection. (At least it does when I use "External" on a networked drive.)
We set up our workstations to move everything like this off to a non boot drive/partition, so yes this is totally possible. It's not that straight forward though, i.e. you can't do it in Avid (that I'm aware of).
Kevin is correct in terms of selecting "External" for your project, but our Attic still stays local (in the default directory) unless we are using Avid Style spaces on our EditShare.
Otherwise, the most robust way to do this for "Private" and "Shared" projects, and the Attic, is to use "symlinks" - symbolic links - to redirect everything to a different location. If the location disappears, or moves, the (sym)link will be broken so the location you are redirecting to needs to be permanent (like a second hard drive, or partition) and not dynamic (pen drive, portable hard drive, networked share) lest you have it attached everytime Avid is running.
The command to create a link is:
ln -s /path/to/original/ /path/to/link
To remove it is:
unlink /path/to/symlink/
Symlinks are basically like shortcuts on steroids and it's important to note that removing/deleting the symlink does not delete the files, it just removes the shortcut if you will.
Hope that helps!
