Latest post Sun, Apr 30 2017 8:54 PM by bobbybz. 3 replies.
  • Sun, Apr 30 2017 5:57 PM
    • bobbybz
    • Joined on Mon, Oct 26 2015
    • Posts 47
    • Points 615
    ProRes Import and Conslidate woes- Audio Static in ProRes clips
    Running Media Composer 8.8.1 on a windows 7pro workstation (details below). The DP shot XAVC HD clips on a Sony FS7 but the network requires that we convert all the raw clips to ProRes 422. The final piece also needs to be delivered in that format, so  I figured I would also bring the ProRes clips into avid and edit in that format.
    I used a third party program to convert the XAVC files into ProRes 422, and upon playback there is no video or audio issue with the converted files. I then first tried fast importing these into AVID, but once the file was imported I would get "Core Consistency Check Failure" in the source monitor. Alternately, I successfully AMA linked to the ProRes files (which also look and sound fine- so there is no issue with the original converter) and then conslidated them to a new media drive. This seemed to work, except I'm noticing a problem with the second audio channel. Consistently, there is a multi-frame loud static blip that comes up throughout all the clips at random intervals. This is a problem across all the consolidated media. I can't seem to figure out why. Any thoughts?
    HP Z440, Intel Xeon E5-1650v3@ 3.5GHz, 32GB RAM (2x16), Windows 7Pro 64bit - Service Pack 1, Nvidia Quadro K2200 (driver v441.28), Blackmagic Decklink... [view my complete system specs]
  • Sun, Apr 30 2017 6:39 PM In reply to
    • bobbybz
    • Posts 47
    • Points 615
    Re: ProRes Import and Conslidate woes- Audio Static in ProRes clips
    For anyone else that has seen this issue- it seems I neglected to choose to convert the clip's sample rate to the project's. Turns out, the source clips were 44khz. Choosing to make them 48khz removed the static issue.
  • Sun, Apr 30 2017 7:21 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    To be able to work with Prores , an Apple codec , all the way though , you need a Mac , there is no Apple PC support for APR
    Tomas
  • Sun, Apr 30 2017 8:54 PM In reply to
    • bobbybz
    • Posts 47
    • Points 615
    Unfortunaltey, the problem didn't go away as I thought. It just switched the static issue from channel 2 to channel 1.. Even if ProRes isn't supported by AVID for PC, it's still a strange issue. I'll just have to edit in AVC and deal with it for deliverables.
