Latest post Tue, May 9 2017 9:51 AM by mjolnarn. 20 replies.
Page 2 of 2 (21 items) < Previous 1 2
  • Fri, May 5 2017 8:34 AM In reply to
    • DIESELE
    • Joined on Mon, Apr 28 2008
    • Posts 1,202
    • Points 14,855
    Re: Media Composer 8.8.2 NOW AVAILABLE - 11 April 2017
    touviere7:
    i was wondering if anything can be done to use again monitors with different resolution simultaneously, like in a few versions back...?
    +! - many of us are STILL sitting on 8.6.5 due to this and the render glitching issue.
    Symphony 2018.12.10, Blackmagic Intensity Pro 11.1 (unsatisfactory in full res UHD though for client monitor), WIN 10 on 2500Mbps M.2 SSD, Nvidia Quadro K4200, Asus X99-A Mobo, i7 5820K 4.0 GHz Hex core mildly overclocked CPU, 32Gb 2800 Mhz RAM, WD Black 8Tb RAID10 array @ 450Mbs
  • Fri, May 5 2017 8:40 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    DIESELE:
    Fix might be close now Cool
    Tomas
  • Fri, May 5 2017 8:45 AM In reply to
    MC 8.8.2. always gives error message when shutting down application on my system!??
    MC 19.07, WIN 10 x64, HP z840, dual E5-2640v3 2.6Ghz, 8x4GB RAM, Nvidia Quadro M4000, MXO2 LE, Artist Mix [view my complete system specs]
  • Fri, May 5 2017 10:00 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Michael from cologne:
    It´s your Matrox unit, Avid broke this with the latest versions , just press OK when you get that message
    Tomas
  • Tue, May 9 2017 8:18 AM In reply to
    thanks, yes, the matrox is the problem probably.
    I also get some serious glitches in the composer and client monitor when using realtime effects (Marquee Title). As far as I can see also caused by the matrox unit.
    I have to do some more serious testing...
    Michael
  • Tue, May 9 2017 9:51 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Michael
    Not seen any glitches with Matrox preview, using Marquee myself from time to time but always render it
    Tomas
