Latest post Fri, Dec 30 2016 1:36 PM by BobRusso. 14 replies.
Page 1 of 1 (15 items)
  • Wed, Dec 28 2016 3:02 PM
    • SJ04
    • Joined on Fri, Dec 4 2015
    • Posts 33
    • Points 465
    installtion and configuration of ISIS client manager in Linux cent os.
    avidHey Guys,
    Please provide me any help with connecting the isis Client manager with Virtual Cent OS Server. I have download the client for linux from ISIS 5000 interface. I have also installed it and not understanding how can i start the client and check the connection.
    please help me figure out ,
    how can i properly install it and make it work.
    thank you .
  • Wed, Dec 28 2016 3:31 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,436
    • Points 30,240
    • ! Avid Employee
      Moderator: Avid ISIS
      Moderator: Avid NEXIS & NEXIS EDGE
    Re: installtion and configuration of ISIS client manager in Linux cent os.
    What version of CentOS are you running? What version of ISIS are you running?
    If you're running ISIS 4.7.5 or later - and you should be - I suggest using the NEXIS 7.1 client that's available on the Avid download center.
    CentOS 6.5 is supported. The client currently isn't supported on CentOS 6.7 and 7.
    Ensure that CentOS has a Computer Name.
    The client itself is under Applications > System Tools.
  • Wed, Dec 28 2016 3:39 PM In reply to
    • SJ04
    • Posts 33
    • Points 465
    Hello Bobrusso,
    thank you. I have cent OS 6.5 as linux server. where i want to install the client and ISIS 5000.
    can you please provide me links and documents which i can use while working on it.
    thanks
  • Wed, Dec 28 2016 3:51 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,436
    • Points 30,240
    • ! Avid Employee
    All the ISIS 4.7 docs are here. As root install the .bin file using the terminal; for example:
    sudo /home/user/Desktop/AvidNEXISClient_el6.x86_64_7.1.0_125.bin
    Again, I suggest installing the NEXIS client as there are known issues in the ISIS Linux Client.
  • Wed, Dec 28 2016 4:23 PM In reply to
    • SJ04
    • Posts 33
    • Points 465
    thank you bobrusso,
    i am gonna try with nexis client, if the linux server is virtual machine it also works.
    and i didnt find the installer for it.
  • Wed, Dec 28 2016 4:35 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,436
    • Points 30,240
    • ! Avid Employee
    The same client is used for a VM.
  • Wed, Dec 28 2016 5:01 PM In reply to
    • SJ04
    • Posts 33
    • Points 465
    Hello BobRusso,
    I have downloaded the AvidNEXISClient_el6.x86_64_7.1.0_125.bin.zip and this client this client i can now install on the Linux Client.
    is there any special depandanicies which needs to be installed on the cent os, becasue according to cent os docuemnt, we can just run the bin file.
    and do we need to put the installer into some specific direcotry or i can just exract anywhere instead of User home directory.
    thanks
  • Wed, Dec 28 2016 5:11 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,436
    • Points 30,240
    • ! Avid Employee
    We technically only support Red Hat 6.5 but have never heard of any issues installing the client on CentOS.
    The details on how to install the Linux Client are on page 10 of the Client Guide. I'm unaware of any dependencies that are required to install a .bin file - what I detailed is how I install the client.
    The instructions in the client guide are different.
  • Wed, Dec 28 2016 6:14 PM In reply to
    • SJ04
    • Posts 33
    • Points 465
    i have installed the client but i am having trouble with connecting to server. I tried to add the server but its not showing up in the server connection page.
    virtual Machine is in diffrenet Vlan then the ISIS but all the port are open between the linux machine and the Avid ISIS server.
    please advice.
  • Wed, Dec 28 2016 7:45 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,436
    • Points 30,240
    • ! Avid Employee
    Add the IP address of the System Director to the Remote Hosts in the client. The VM must have a host name.
  • Thu, Dec 29 2016 11:53 AM In reply to
    • SJ04
    • Posts 33
    • Points 465
    Hey Bobrusso,
    thank you. i have added the System directory IP in the Nexis client manager but it shows nothing. there is also no error message so i can understanfd what can be worng.
    please help.
  • Thu, Dec 29 2016 1:49 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,436
    • Points 30,240
    • ! Avid Employee
    Is there a NIC selected in the client manager? Is this the correct network to reach the System Director? Can you reach the management console with a browser?
  • Thu, Dec 29 2016 6:20 PM In reply to
    • SJ04
    • Posts 33
    • Points 465
    Hey , yes i can reach the web interface from the browsser. but it is still not showing up in the Nexis Client.
    but still the Server connection doesnt show up.
    to be clear the Network adapter is configured to the Nexis Client to use within the Client manager. but this Network adapter is in the diffrent Vlan and i have configured the routing between the system director and linix client .
    should i try to provide the new network adapter to the Linux client and put this vlan in the same vlan as System director.
    Please advice. thanks
  • Fri, Dec 30 2016 12:21 PM In reply to
    • SJ04
    • Posts 33
    • Points 465
    hey Bobrusso,
    I have assigned the new network card which is in the same Network as System director and system directory just simply shows up in the System panel.
    but there is just problem with Login , I can't authenticate with server even the same login detial works with other windows machine client.
    is there anything which needs to be considered here.
    thank you for your help.please advice me something here.
  • Fri, Dec 30 2016 1:36 PM In reply to
    • BobRusso
    • New Jersey
    • Posts 2,436
    • Points 30,240
    • ! Avid Employee
    Every computer, including the VM, must have a host name/computer name. If you look in the management console under devices and/or connection status you will likely see a computer without a name or random characters.
