Latest post Fri, Oct 28 2016 3:05 PM by John Mac. 7 replies.
  • Thu, Oct 27 2016 7:34 PM
    • John Mac
    • Posts 184
    • Points 2,465
    PDZK-MA2 v3.51 will not install
    Hi, anyone having problems with PDZK-MA2 v3.51.
    It keeps offering a dialogue box telling me to uninstall earlier version - but this does not exist after uninstalling previous version. So stuck basically meaning cannot seem to relink any ex1 ie older XDCAM footage
    John
    MC 8 Windows 7 Pro 64-bit i7 Intel Core 4 cores 3.5 GHz 16 Gb ram Nvidia quadro 4000 Matrox mini 6TB internal connected to SATA III ports [view my complete system specs]
  • Thu, Oct 27 2016 7:47 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,808
    • Points 31,120
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Re: PDZK-MA2 v3.51 will not install
    Hi John,
        How about uninstalling the old version from the Windows programs and feature does it help?
    Regards,
    Ralph
    MacBook Pro 15 2018 Intel Core i7 2.6GHz Mac 10.15.7 Intel UHD 630. [view my complete system specs]
  • Fri, Oct 28 2016 1:17 AM In reply to
    • John Mac
    • Posts 184
    • Points 2,465
    It was completely uninstalled but for some odd reason the installer doesn't see it that way. I have tried reinstalling previous version (which does install) and then uninstall again. But latest codec simply will not install
    John
  • Fri, Oct 28 2016 11:22 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    John Mac:
    John
    I didn't have a problem. Have you got anything odd installed like Quicktime Alternative? Next best bet is something like Revo to completely clean up the install..
    John
  • Fri, Oct 28 2016 11:31 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,320
    John Mac:
    Have you tried to remove them all from inside Avid/AVX2/ama
    Tomas
  • Fri, Oct 28 2016 11:49 AM In reply to
    • Thanski
    • Joined on Wed, Nov 18 2009
    • Posts 20
    • Points 285
    I found there's a problem with Sony installer. I unistalled previous PDZK-MA2 plugin and after that I had to manually delete empty XDSDeck folder found in C:\Program Files\Avid\AVX2_Plug-ins\AMA\. After that I was able to install PDZK-MA2 v. 3.5.1.
    Tero
  • Fri, Oct 28 2016 1:34 PM In reply to
    • John Mac
    • Posts 184
    • Points 2,465
    have done a total trawl and cannot find traces - even used Revo Uninstaller but still get the same message that I must remove an earlier version
    John
  • Fri, Oct 28 2016 3:05 PM In reply to
    • John Mac
    • Posts 184
    • Points 2,465
    Ah, great - tried that and you;re right, it did the trick! Thanks
    John
