Hello,
I have 600 images to Link in Media Composer, and I can't figure out if there is a way to increase/decrease the time duration these run for.
The default seems to be 30 seconds.
I know how to adjust the duration when Importing, but as I don't want to import them - is there a way to do this with Linking (AMA) images?
Thank you!
With linking the default is 30 s. However, it does not change the size on disk, even if it could be set to 1 s, as linking only stores a link to your image.
The problem comes with transcode, as the transcode command would build video-files of 30s length. To avoid this, use your images in the timeline in linked mode, and make a transcode of your finalized timeline. Images (and clips) are then transcoded to the length in the timeline plus handles at the beginning and the end (to be set at the top of the transcode window).
Joachim
Joachim Claus
Link them all to a bin.
Go to script mode
Press Ctrl-a to select all.
Press G to clear all marks ( just to be sure )
Press T to select in to out
Press Q to go to in
Press the button 2 to step 10 frames for each step, if you press it 3 times you have a leeway of 30 frames.
Press I to select the inpoint
Continue to press 2 to step forward , if you want the clips to be 200 frames in length you press 2 10 times.
Now press O to select the outpoint
All images are now of the same length , shortened and with leeways created
Tomas
Nice tip Tomas!
Didn't knew about using the step 10 frames in the Script Bin View. It's really useful for large photomontages.
Sylvain Primeau
Self-employed worker - Les productions Primeau Medias
primeaumedias.com
Radio-Canada/CBC news editor
cbc.ca / ici.radio-canada.ca
Hi Sylvain , glad you liked it , an old tip that I use myself rather frequently for fast turnarounds , remember that Liquid option " master clip with handles "
Works well even on ama linked camera clips, Q for go to mark in and 3 taps on 2, press I , then W and 3 taps on 1, press O , gives you masterclips with 30 handles, as all of them already are selected just to mouse drag to the sequense
Hi there!
It's a really nice tip. However, ir doesn't actually answer the question. For instance, I want to link an image to last for 6 minutes, without having to replicate it across the sequence (in this case, 12 times). How do I do it?
Thank you all in advance.
Miguel
Media Composer editor, since 1997.
You can use either the motion editor on the clip or the timewarp effect in the sequence. The easiest thing to do is to change the duration of the clip from 30 seconds to 6 minutes. If you do this with the motion adapter on the clip and then drop it in the timeline, it will be 6 minutes long. If you promote the adapter to the timewarp effect for clips in the timeline, changing the duration will not extend the clip in the sequence. You must also drag the handles of the clip out to 6 minutes. You should also change the speed graph to 0%. This is a freeze frame (which you might get anyway it being a static image). This is all documented in the manual in the section on Using the Motion Effect Editor. You can also find online tutorials. It's easier to learn by watching a video tutorial then reading the book.
Dave S.
hi mjolnarn
thank you for this advice. just awesome.
i had to edit round 5k stills in 6k resolution with 3 frames duration. ahhh!
so i am very thankful for this.
i've mapped a "step one frame forward" on a different key and it works fine.
for finetuning. the cursor keys won't do it.
well. saved a lot of hours on cutting frames.
I am editing for 20 years on avid and i never knew how powerful scriptmode is.
thanx!
best from berlin
benjamin
http://www.imdb.com/name/nm0702705/
one of the best reasons this Avid Community is so crucial and helpful! Thanks for this very obscure and incredibly powerful tip!
Owner, Emperor - Bill Nelson Media Group
Managing Partner - FirstLight Independent
www.forrobbingthedead.com
Just searched for 'adjust image duration when importing' and this is tantalising!Natisyahu, you know how - can you share with me?
(Love this forum and have been missing it in retirement - dipping back in for a couple of tiny projects...)
Susi: image duration when importing
In your Import settings > Image tab, there is a box at the bottom left that says 'Frame Import Duration' with a box next to it that allows you to type in a number of seconds.
Note: I *think* but I don't remember for sure that the max is 120 seconds.
Actually, I don't know of there is any limit at all. I import my images to last an hour, for liong lasting backgropunds or backdrops. I just type in 3600 seconds and that's it.Do note that this doesn't work when your're linking, instead of importing.
Miguel:Actually, I don't know of there is any limit at all. I import my images to last an hour, for liong lasting backgropunds or backdrops. I just type in 3600 seconds and that's it.Do note that this doesn't work when your're linking, instead of importing.
Good tip! Thanks, Miguel!
Yep. It would be nice to have that option for both importing and linking. (I have no idea how hard or easy that would be to implement.)
camoscato: Good tip! Thanks, Miguel!
My pleasure, camoscato. Always glad to help!
