Latest post Tue, Sep 13 2016 4:28 AM by mjolnarn. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Sep 13 2016 4:00 AM
    • Davelip75
    • Joined on Fri, Feb 19 2010
    • Posts 33
    • Points 430
    Cut on MC 5.5.5 - Footage now soft in MC 7.0?
    Hi there, I have a documentary, original shot on VHS, 4x3. The footage has been imported 1:1, and edited in an SD 30i project.  The project was cut on Avid 5.5.5 (important...)
    As per advice,  for finishing purposes, I brought the locked cut into a 1080i 59.94 project. In order to retain the 4x3 look, I'm using the REFORMAT effect on V6 (Video Track 6). And on V7,  I have a video mixdown of the final locked cut, rendered at DNx145HD. The video mixdown on V7 is sharp and clean.
    However, I jumped onto an Avid MC 7.0.4 system, and all of the original 1:1 footage (Not the mixdowns) when viewed using the Reformat effect on V6, are now SOFT. When I compare between V6 (reformat layer) and V7 (mixdown), V7 is still sharp & V6 is dull & soft. This is happening only when i use the MC7.0.4 system, NOT the MC5.5.5 system.
    As a test, I tried doing a new mixdown of the same footage, while on MC7.0.4, and when I compare the mixdown created on MC 5.5.5, and the current system, the mixdowns are SOFT.
    I double checked all the media creation and render settings, which are either at Automatic or FULL (highest quality) for renders/mixdowns, etc.
    Is this a known bug? What is my work around?  The only difference I can think of, is this 7.0.4 system does NOT have BCC efx loaded. It is also prompting me to "update sequence to promote missing plug-ins to AVX 2.0"
    Help?
    Mac OS 10.6.8 2 x 2.66GHZ dual core Intel Xenon 20GB 667MHZ DDR2 MC 5.5.5 [view my complete system specs]
  • Tue, Sep 13 2016 4:28 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: Cut on MC 5.5.5 - Footage now soft in MC 7.0?
    Davelip75:
    Would be quite easy to check what effects that is used on the origin . 5.5.5 system and, if for example, BCC Uprez , a very good upscaler, is used on the origin system, it of course also needs to be installed on the 7.0.4 system.
    Later systems needs 64 bits plugins for your info
    Tomas
