Latest post Tue, Oct 25 2016 8:58 PM by gorky. 7 replies.
  • Sun, Sep 11 2016 9:17 PM
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 154
    • Points 1,880
    MC 8.6.3 and Baselight plugin
    Baselight plugin does not work properly in new MC 8.6.3 version.
    I can't jump no more between previous and next cips in sequence. F5/F6 does not work anymore.
    Something wrong witt AVX block in new MC. Sad
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Mon, Sep 12 2016 6:55 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Re: MC 8.6.3 and Baselight plugin
    Works excellent here on Win10.
    I would recommend to check the usual stuff as a new user and to clean up the application settings.
    Tomas
  • Mon, Sep 12 2016 8:50 AM In reply to
    • gorky
    • Posts 154
    • Points 1,880
    Did not help.
    Maybe it's only Mac bug.
  • Mon, Sep 12 2016 4:24 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Ok, couldn´t see anywhere that you was on using a Mac, just tested with 8.63 under 10.10.5 and all worked as it should, I might be using a more updated version than you though and as noted elseplace the latest Avid version needs updated filters.
    Tomas
  • Mon, Sep 12 2016 4:37 PM In reply to
    • gorky
    • Posts 154
    • Points 1,880
    Do you tested F5/F6 shortcuts?
  • Mon, Sep 12 2016 4:45 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    gorky:
    Yes, of course
    Tomas
  • Mon, Sep 12 2016 4:48 PM In reply to
    • gorky
    • Posts 154
    • Points 1,880
    Thank you. I'll dig deeper.Huh?
  • Tue, Oct 25 2016 8:58 PM In reply to
    • gorky
    • Posts 154
    • Points 1,880
    After almost a month of use MC 8.6.3 and Baselight plugin I have to admit that if I have on timeline 4K clip in HD project F5/F6 does not work to all clips lying right to 4K clip. So I might use FX with fillers above clips.
    I see that behaviour only in last MC version.
