Latest post Sun, Feb 26 2017 5:45 AM by Zingara. 64 replies.
Page 1 of 5 (65 items) 1 2 3 4 5 Next >
  • Fri, Sep 9 2016 1:12 AM
    • klein19
    • Joined on Sun, Apr 16 2006
    • Montreal, Qc, Canada
    • Posts 137
    • Points 1,695
    8.6.3 Crashes on startup
    Just installed 8.6.3 and crashes every time before I even get to the load project window. Uninstalling and going back to 8.6.1.
    First time I ever had this problem on this system. MC has always run flawlessly.
    Anyone else had this problem?
      Mac Pro Late 2013
      12-Core Intel Xeon E5 2.7 GHz
      Memory: 64 GB
      OS 10.11.5
    MacPro 2.7GHz 12 core, 64GB RAM, Dual AMD FirePro D700 [view my complete system specs]
  • Fri, Sep 9 2016 2:04 AM In reply to
    • jdrouette
    • Montréal, Canada
    • Posts 469
    • Points 6,170
    Re: 8.6.3 Crashes on startup
    Do you happen to have the Matrox driver (OpenIO_Matrox.acf) in your AVX2_Plugins? I have found that this driver crashes MC 8.6.2 and 8.6.3 on startup, and that removing it (or rolling back to 8.6.1) solves the problem.
    jd
    Avid Media Composer 2022.4 Symphony option, Blackmagic Design UltraStudio 4K Mini (Desktop Video Application 12.3), macOS 12.4, Macbook Pro 14" (2021... [view my complete system specs]
  • Fri, Sep 9 2016 8:56 AM In reply to
    • JKL32
    • Joined on Sat, Dec 22 2007
    • The Netherlands
    • Posts 210
    • Points 2,945
    klein19:
      Mac Pro Late 2013
      Memory: 64 GB
      OS 10.11.5
    Yep! It still crashes!!!!!!!! Just like 8.6.2! Can't believe this!
    Avid Media Composer 8.6, BMD UltraStudio Mini Monitor(Desktop Video 10.8), New Mac Pro 8 core, D700, 64g RAM, El Capitan [view my complete system specs]
  • Fri, Sep 9 2016 9:26 AM In reply to
    I can also confirm that in my case the crashing on launch was also related to the Matrox file.
  • Fri, Sep 9 2016 10:04 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    lighthouseman:
    I´ve seen that coming so I´ve stayed on 10.10.5 as my mobile Matrox playouts are far more important than having the latest and greatest from Apple .
    Tomas
  • Fri, Sep 9 2016 10:48 AM In reply to
    Just trying 8.6.3 here. Launched once but saw an anomaly with the HD 100pct colorbars file in a 1080i/50 project - the duration reported as 29.29 (think about it). Quit, restarted computer and 8.6.3 crashed as described on launch. Trashed MCState and User profile. Crashed 3 times so going back to 8.6.1 which has been sweet on my system (iMac 3.2 GHz Intel Core i5, 24GB RAM, OS 10.11.6). i do have MAtrox utilities still in place but no Matrox hardware. I will try deleting hte Matrox files.
    iMac i5 27", 40GB RAM, OS 11.6.4 with MC 2022.7 with Symphony option, BlackMagic 4K. 2020 MacBook Air with MC 2022.7 ... and NewsCutter 7.x on Dell... [view my complete system specs]
    ACI, Dorset, UK. www.avid-companion.co.uk
    Filed under: , ,
  • Fri, Sep 9 2016 11:01 AM In reply to
    Deleted the Matrox utilities and we are up and running with 8.6.3. I sold the Matrox box last year so I should have got shot of the files anyway.
  • Fri, Sep 9 2016 11:38 AM In reply to
    • JKL32
    • The Netherlands
    • Posts 210
    • Points 2,945
    I use Black Magic Design UltraStudio Mini Monitor with Desktop Video Setup. And I need it. Rolled back to MC 8.6.1 again..
  • Fri, Sep 9 2016 11:45 AM In reply to
    And that crashed your system? I have the Blackmagic drivers. I'd better connect the Mini Monitor ....
  • Fri, Sep 9 2016 11:57 AM In reply to
    • JKL32
    • The Netherlands
    • Posts 210
    • Points 2,945
    Roger Shufflebottom:
    I don't know if that causes the crash. I just installed MC 8.6.3 with a kind of confidence that the installer is now fixed, so I just installed the BMD Desktop Video Setup right after it. The first startup Avid crashes, so angry again I uninstalled everything again and just rolled back to to MC 8.6.1. I don't want to spend hours on a installer or MC version that won't work as before. Its ridiculous.
  • Fri, Sep 9 2016 11:58 AM In reply to
    No problem here with 8.6.3 and Blackmagic Mini Monitor.
  • Fri, Sep 9 2016 12:53 PM In reply to
    • Verne Mattson
    • Joined on Sat, Nov 19 2011
    • Northern New Jersey
    • Posts 24
    • Points 300
    I'm seeing the same crashing.  I don't have any Matrox drivers, but I do use BMDs Desktop Video.  I've rolled back to 8.6.1.
    Verne
    2019 MacPro 16 core 96GB RAM [view my complete system specs]
  • Fri, Sep 9 2016 4:19 PM In reply to
    • RalphC
    • Joined on Wed, Sep 2 2015
    • Posts 2,855
    • Points 31,590
    • Avid Customer Advocate
      Avid Customer Service
      Avid Employee
    Hi JKL32, klein19,
     I'm creating a support case 03034594, include you both.
    Regards,
    Ralph
    MacBook Pro 15 2018 Intel Core i7 2.6GHz Mac 10.15.7 Intel UHD 630. [view my complete system specs]
  • Fri, Sep 9 2016 8:11 PM In reply to
    Verne:
    FWIW I have 8.6.3 running happily on OS 10.10.5 (like Tomas) and with BM desktop 10.4.2 running a Decklink Extreme 3D.  (Both 8.6.2 and 8.6.3 installed and worked on this (older) MacPro)
  • Fri, Sep 9 2016 8:13 PM In reply to
    • Jim Blokland
    • Joined on Mon, Nov 28 2005
    • Guelph, Ontario
    • Posts 227
    • Points 2,835
    Add me to the list!  I have the Matrox MXO2 Mini – worked fine with 8.6.1.  Crashes AVID 8.6.3 on startup.  I removed the OpenIO_Matrox.acf driver, and MC opens, but doesn't seem the Matrox box at all – no external monitoring!
    Thanks, JIM.
    MC 2021.12 Monterey 12.1 M1 mini 16 GB RAM BM DeckLink Mini Monitor 4K [view my complete system specs]
    JAMES BLOKLAND
