Latest post Mon, Oct 24 2016 1:53 AM by Ronald Czarnecki. 46 replies.
Page 3 of 4 (47 items) < Previous 1 2 3 4 Next >
  • Tue, Sep 6 2016 1:17 AM In reply to
    Re: Change a mixdown resolution or relink it to 4k
    Picture of the AVCHD I had on my hard drive which I linked using private folder.
    MC Version: 2018.2 System: PC windows 7 Pro 64 bit, Workstation ATX mid Tower case, MSI Z87-G45 MBoard, 650 watt,Crucial M500 250GB SSD, Intel i7-4770K... [view my complete system specs]
    MC 8.4.5     Built Workstation-Windows® 7 Professional, 64bit,/ Intel® CoreTM i7-4770K processor/ NVIDIA Quadro K2000D 2GB/16GB Dual Channel DDR3 SDRAM at 1600MHz /MSI Z87-G45 Mother Board/650 Watt Power/ Super Multi Blue Writer (LG BH12LS38)/ AVID C-400 for audio interface  Pro Tools MP
  • Tue, Sep 6 2016 1:32 AM In reply to
    BarkinMadd:
    You basically need to manually build a sync map sequence with all your camera angles and then cut that up into multiple grouped clips. Pain but apparently the best way to allow for offline edition followed by relinking to original source clips. There are some very good articles on this workflow but I've never used it myself.
    I did a quick look up and it says to use a seperate video track for each clip or for each camera but then it says to use plural eyes to sync all these clips.  That would be hard with so much footage. This seems for cinematographers doing interviews.
    http://willblanksblog.blogspot.com/2014/05/how-to-multigroup_15.html
    I did just realize although I am not updated to 8.5 they now have Pluraleyes.
    Let’s Edit with Media Composer – ADVANCED – Multicam Editing in v8.5
    waveform sync
    https://www.youtube.com/watch?v=u9whtzAn2rA
  • Tue, Sep 6 2016 3:57 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Ronald Czarnecki:
    smrpix tried but top folder does not span the linked clips. Here is the folder structure:
    I have a JVC GY-HM170ua
    https://www.bhphotovideo.com/c/product/1194106-REG/jvc_gy_hm170ua_4kcam_compact_professional.html
    My camera options are:
    Open SD card
    -DCIM/100JVCPR/quicktime files
    -Private/JVC/CQAVC=Clip & Info
    This camera can dual record differenct formats at the same time, hence the two different folders. I tried some AVC with the private folder as a top folder but it not did create a spanned clip.
    Ok, I see, would you like to do this test for me, and maybe with a later version than 8.45 , no idea if that matters though.
    1: Create a folder on your media drive, maybe not to deep buried down in the folder structure, and maybe just name it TEST
    2: With the SD card mounted in your card reader, ( and be sure to have the option to see all files and folders in the windows OS enabled in the OS settings ) open up the card and copy the entire structure to that test folder.
    3: With Avid opened up, alt drag that TEST folder to a new bin to find out if this workflow makes any difference re spanned clips
    Tomas
  • Sat, Sep 10 2016 2:26 AM In reply to
    Thanks but it is not possible to drag a folder into a bin, nor is it possible to drag any of the QT files into the bin. You have to link or import.
  • Sat, Sep 10 2016 7:01 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,944
    • Points 70,235
    Dragging clips is indeed possible, but Tomas wrote ALT-drag, which might also work with folders.
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Sat, Sep 10 2016 3:31 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    Alt-drag triggers a link (AMA) operation.
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Sat, Sep 10 2016 4:27 PM In reply to
    Tried the Alt drag for top and every folder down from there. I see where is it possible from the forum discuccion below however it mentions using MXF clips. I am using QT maybe that is the difference.
    https://forums.creativecow.net/thread/45/898953
  • Sat, Sep 10 2016 5:31 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Ronald Czarnecki:
    Ok , so .. maybe it matters
    " Ok, I see, would you like to do this test for me, and maybe with a later version than 8.45 , no idea if that matters though. "
    Tomas
  • Sat, Sep 10 2016 10:58 PM In reply to
    I am now on 8.6.3 and yet I could not move a folder for linking. I even tried some MXF folder I had. Maybe this is just for AVCHD. Does Avid have some material on how this works and for what formats?
    Here is a video link of what I tried.
    https://vimeo.com/182246909/04bda76364
  • Sun, Sep 11 2016 1:06 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,818
    • Points 63,185
    I'm running 8.6.2 before it got yanked. I hold the ALT key down then click on a folder and drag it over a bin (not over the source browser). When I drag over the bin I see the drag icon change and the word 'Link' is clearly visible. I then releaes the mouse button (still holding the ALT key) and the files within the folder automatically link and I see them in the bin.
    I watched your video and I can't understand why it doesn't work.
    Caveat - I only have XAVC-L MXF files to play with on my system at the moment - no QT files. And I don't have any UHD files so that could be the issue, I suppose.
    I'm running a 1080p project @29.97 fps, MC 8.6.2 and Windows 10.
    Steve
  • Sun, Sep 11 2016 1:10 AM In reply to
    We will see if anyone else may know. I was holding the Alt key all during the video when moving the folders.
  • Sun, Sep 11 2016 7:37 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    First it seems like you have a system or user setting error, alt drag should link and dragging files with no alt should import so I would start with the usual troubleshooting stuff as trashing all but the defaults settings and starting up as a new user.
    Second, now that you are on 8.63 with the source browser that browser should bring spanned files together as one clip, how about that one.
    add....  and third, did you make sure to have " show hidden files and folders " enabled in your Windows OS, some cards have hidden files, the FS 700 cards always have an avf_info folder hidden as an example and without that one present not even Sonys own software handles those cards correct
    Tomas
  • Sun, Sep 11 2016 8:11 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,944
    • Points 70,235
    Indeed Ronald's system doesn't work as it should with regards to the ALT-drag thing, but after a second look at the screenshots posted, the clips in the bin are not all of the same duration, so this is not a case of spanned clips not stitching toghether, but it's the camera operator who brought home mince meat instead of the entire beef.
    peace luca
  • Sun, Sep 11 2016 8:53 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Nice find Luca, I´ve also just created a small screenshow
    http://www.raggartv.se/filmer/tuts/avid_spanned_clips.html
    Tomas
  • Thu, Sep 15 2016 12:39 AM In reply to
    Thanks for trying to figure this out. I watech the video and see you can do the transfer but I can not figure it out. I tried all your request:
    1. Using a fresh profile
    2. Setting for show all files
    3. Created a spanned clips of the camera just video taping the TV for 20 minutes.
    4. I used the source browser but it just made separate links files.
    I made sure all the clips were the same duration except for the last clip which was the end.
    Unless I am missing a type of plug in for linking JVC clips I don't know why it is different other then you are using Sony clips. I also tried Sony HXR-NX3 AVC clips and Canon XF-100 MXF folder.
    I think I will call Avid Support techs and see if they can screen share with me. I will write back here when I find what the problem is.
