Latest post Wed, Jan 20 2016 5:02 PM by TCurren. 2 replies.
  • Thu, Jan 14 2016 6:12 PM
    • editmarx
    • Burbank CA
    • Posts 103
    • Points 1,235
    Pan and scan
    I just got a client request to have me handle the pan and scan for the UK distributors.  They're going to provide me with the 2k ProRes HQ master.
    Is there a tutorial available?  I'm debating between doing this as an add edit with frame flex adjustment or just through the Pan and Zoom tool.
    Then there's something I notice when doing outputs to QT that shots pick up additional contrast in shadow areas.  Am I alone in this?  Is there anything I can do other than running a small brightness or contrast filter at the output stage?  Not my favorite idea.
    8.68.2, DNXIO, Avid Artist Color, Symphony, Mac Tower, 2.7 GHz 12 Core Intel Xeon E5, 64GB RAM, AMD FirePro D700 6144 MB [view my complete system specs]
  • Wed, Jan 20 2016 4:54 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,995
    • Points 38,060
    Re: Pan and scan
    I would do it with the Pan & Scan. More importantly, can you get an EDL for the film? If you can, there is a sneaky workaround to automatically add the edits to your timeline.
    If not, use Resolve and you can have it automatically add the edits.
    Here is a tutorial for Pan & Scan. (Not pan & zoom which does something else.)
    https://vimeo.com/26031219
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Wed, Jan 20 2016 5:02 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 2,995
    • Points 38,060
    Re: Pan and scan
    editmarx:
    You may be mixing RGB & 709 levels. Without seeing the exact issue it is hard to evaluate. here is a good primer in PDF format:
    709 vs RGB in Avid
    Burbank, Ca
    www.alphadogs.tv
