Latest post Mon, Feb 15 2016 1:47 AM by Robert A. Ober. 15 replies.
  • Tue, Nov 24 2015 4:09 AM
    • Hunna
    • Joined on Wed, Nov 27 2013
    • Posts 2
    • Points 50
    Avid v XAVC-S codec
    Hi Everyone,
    I've tried many times to use the XAVC-s with Avid, like most to no avail.
    I have been shooting in AVCHD on my A7S and AMA linking into AVID, which is OK but I really want to use the better quailty of XAVC-s.
    There must be a way to work this out.
    Help please,
    Andrew.
  • Tue, Nov 24 2015 4:31 AM In reply to
    • hbrock
    • Bainbridge Island, WA
    • Posts 5,586
    • Points 65,025
    • Moderator: MCA Mac
    Re: Avid v XAVC-S codec
    Avid doesn't support XAVC-S because Sony hasn't provided a AMA plugin that works with XAVC-S.  You'll need to use another program to convert the XAVC-S into a compatible codec that Media Composer can use.  Here are some choices:
    Edit Ready.  Cheap, fast and it works.  Use the Custom settings for greater than HD codecs.
    Sony Catalyst Browse: Free, slow and limited.
    Sony Catalyst Prep: $199 (might be free if you can provide the A7S serial number), slow but does batches.
    DaVinci Resolve: Free, fast, but chances are the audio won't be read.
  • Tue, Nov 24 2015 4:47 AM In reply to
    • tpowell
    • Joined on Wed, Dec 10 2014
    • Posts 51
    • Points 615
    I have been using Adobe Media Encoder with good success. I bought Catalyst Prepare and it worked for a while, but now it doesn't seem to work. I upgraded so that I wouldn't need to "import" the clips before "exporting" them, but now the Export button is always grayed out. Plus, it is extremely slow. It took me a while to figure out how to find the right settings in Media Encoder, but I have a preset now so it is reasonably fast and smooth, plus you can do a version of batch processing. Hope this helps!
  • Tue, Nov 24 2015 5:52 PM In reply to
    I'll second the EditReady method.  But really, Sony needs to address this.
    New Mac 8 core. 32 Gb RAM D-700 , BMD Ultra 4K, Maxx Digital TB2 RAID [view my complete system specs]
  • Tue, Nov 24 2015 7:18 PM In reply to
    • Posts 12,181
    • Points 262,755
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    Richard
    Doesnt appear that this will be a reality until sometime in 2016.....
    Sr. Director | Customer Experience and Community [view my complete system specs]
  • Tue, Nov 24 2015 7:26 PM In reply to
    Marianna:
    Richard
    I respectfully surmise as a manufactured scheduled.
    MC 2024.12, W11, ASUS z690m, Intel 13900K, MSI 4090 Suprim Liquid, 128GB RAM, Samsung 980 Pro M2 SSD, BM Mini monitor & Dell UP2718Q. MBP 2019, Sonoma... [view my complete system specs]
  • Thu, Nov 26 2015 9:38 PM In reply to
    • jkedit
    • Joined on Thu, Nov 17 2011
    • Bratislava - Slovakia
    • Posts 18
    • Points 210
    I use cliptoolz-v2 (now free) to rewrap the files(no transcoding) to mov container. Then ama linking works flawlessly.
    MC 23.12, 22.12.6, 21.12.10., 22.7, 22.10, 23.3, 22.12.1 10x Hp z4 g4 quadro5000, rtx2080ti, 10gb client Hp z8 g4 dual xeon 384 GB RAM, quadro 5000 ... [view my complete system specs]
  • Fri, Nov 27 2015 3:33 PM In reply to
    Thanks for the tip!
    Which cameras encode to XAVC-S, and what is the extension?
    -Telegram!
  • Fri, Nov 27 2015 4:32 PM In reply to
    • jkedit
    • Posts 18
    • Points 210
    I have experience only with Sony A7s which records files with mp4 extension.
  • Sat, Nov 28 2015 4:51 PM In reply to
    • bonang
    • Boston, MA
    • Posts 442
    • Points 5,550
    In addition to the a7s / a7s ii, the Sony ax100 and rx10 ii also record to XAVC-S as only option in UHD.
    Avid MC 2021.12 with Symphony option | HP zbook 17" G3 / i7 6820HQ / 32GB RAM / 512GB SSD / WIN 10 PRO 64 / nVidia m3000m w/ 461.72 driver / BMD UltraStudio... [view my complete system specs]
    Keith
  • Mon, Nov 30 2015 12:34 AM In reply to
    Hunna:
    Hi Everyone,
    Help please,
    Andrew.
    RAO rule #1,  Start in Resolve.
    I found some XAVC-S UHD (Which is NOT 4K!) clips on the Internet.  I tested with the UHD/23.98 clip by bringing it into Resolve12 with audio and making sure the Resolve timeline played.  I rendered(exported) from Resolve using the Avid AAF Round-Trip preset but with DNxHR HQ instead of the preselected DNxHR 444.   The resulting mxfs where then copied to an Avid MediaFiles/MXF/somenumber folder.
    Upon launching Avid MC/w Symphony 8.4.2 I created a new UHD/23.98 project and imported the AAF from Resolve.  The timeline populated with the clip from Resolve and the video/audio plays correctly.
    People spend so much time trying to get AMA to work when they could use Resolve and be editing.  And if one sends the completed edit back to Resolve then one can reconnect to the original footage to color correct/grade in one of the best tools available.
    I tried this in Resolve Studio but the free version should work as it is able to handle UHD exports.  My step by step outline for using Resolve to prepare media for Avid is at http://www.infohou.com/Opinion.html .
    I am no one's employee and am not compensated by any vendor.
    Y'all take care,
    Robert
    2018 MacBook Pro,I7 2.6GHz/32GB RAM/Radeon Pro 560X 4GB/500GB SSD/External RAID0/Mojave & MacPro Early 2009 24GB/GTX1080Ti/1GB SSD/HIT2TB/WD1TB/ProAvio... [view my complete system specs]
    Robert A. Ober
    IT Consultant, Vidcaster, & Freelance Preditor(Producer/Editor)
    www.infohou.com
    Houston, TX
  • Tue, Dec 1 2015 10:56 PM In reply to
    • mustafa
    • Joined on Mon, May 19 2008
    • New York
    • Posts 17
    • Points 255
    DOM!  Mustafa here.
    We just got a project in with about 60horus of sony av7 footage.  all shot as mp4.  needless to say having majoy issues trying to get this stuff in the system.
    gonna be multicam and grouped.  i have tried the mediareactor plug in and its SO close.  links to ama to the MP4 files...i can see them in the sourece.  but avid will not transcode and consolidate just spits out WRONG FORMAT clips.
    any ideas?  i think they want to keep it in 4k for some reason.
    argh.  hope you are well man!
    new mac pro, promise pegasus 2, aja t-tap, 10.9.4, MC 8.3 [view my complete system specs]
  • Wed, Dec 2 2015 3:01 AM In reply to
    EditReady on OS X can rewrap the MP4 to MOV. This will AMA link in Avid. No transcode, very fast.
    On Windows, you can use for free ClipToolz to do the same thing. However, the software is EOL and a bit buggy.
    Another way is to transcode via Sony Catalyst software.
  • Sun, Feb 14 2016 7:54 PM In reply to
    • Alexey
    • CBC-SRC Moscow
    • Posts 14
    • Points 215
    Rewrap is impossible to edit. I think it is better to transcode to DNxHR SQ.
  • Sun, Feb 14 2016 11:49 PM In reply to
    Exactly - you rewrap it (fast) in EditReady, then AMA/link it into Avid.
    From there, you can do whatever transcode workflow you want.  You can transcode ALL of it, or some of it, or transcode to a proxy for later relink-retranscode, whatever you want.  But a rewrap in EditReady is almost certainly the best way to begin.
    (SYSTEM 1) iMac Late 2012 27" (13,2), Mac OS X 10.15.6, Avid Media Composer 2020.12 w/Symphony, Intel Core i7 3.4 GHz, 32 GB RAM, NVIDIA GeForce GTX... [view my complete system specs]
