Latest post Mon, Nov 14 2016 10:57 AM by Avid. 6 replies.
Page 1 of 1 (7 items)
  • Wed, Oct 21 2015 10:29 AM
    Avid UX Source Timecode in Sequence
    A client wants to transcribe their rushes via the UX. Since it appears you can't load all the clips into the source monitor I decided to create a sequence in the Avid per card. But the biggest flaw is that when viewing the sequence in the UX is that you can't set the timecode in the source monitor to source timecode. The only option is 'Master, Remain and Absolute'. This renders the sequence useless as you really need to be able to view source timecode, seems like a pretty basic feature to be missing.
    If you place a timecode generator on it for 'source timecode' of course you need to render it which would take too long.
    Am I missing something here? Viewing source timecode on a sequence checked into the UX...
  • Thu, Oct 29 2015 4:21 PM In reply to
    Re: Avid UX Source Timecode in Sequence
    We also have the same problem: Our authors and customers used to review their footage using sequences with burnt in source timecode. Now after installing a Media Central Server we wanted to skip exporting long Quick Time Files so the authors can review their material on UX.
    But without having the source timecode it doens't make any sense for us. Is this very simple feature already implemented in one of the newer versions 2.3 or 2.4? Unfortunately I dind't find anything about it in the documentations. And if not - will it be implemented in one of the following versions?
    11* Z820 32GB Samsung PCIe SSD with Avid Media Composer 8.5 5 with Nitris DX 1 with Mojo DX 1 with Blackmagic Decklink Extreme 12G some xw8600 with... [view my complete system specs]
  • Thu, Nov 19 2015 10:14 AM In reply to
    We are currently using 2.4.1 and this feature is still missing - like you said it's a very simple feature that would save us in post a lot of time from exporting long sequences for proxies and the like.
  • Mon, May 2 2016 3:29 PM In reply to
    Anyone from Avid care to chip in and tell us when this feature will be added, got clients in again screaming for this feature.
  • Wed, May 25 2016 7:17 PM In reply to
    • Joined on Mon, Mar 30 2015
    • Munich
    • Posts 15
    • Points 155
    Did some investigation: we have this story on the backlog. We are not authorised to publish a release date unless the feature is done.
    Please review this design:
    How to demo
    • Load a sequence
    • Go to the Media Pane
    • Click on the timecode window dropdown
    • Select "Clip"
      • Expected: timecode window displays the clip timecode
        • If there is a gap in the sequence (an area which has no video) then display -:::-
    • Load a clip
      • Expected: "Clip" is selected and behaves the same as "Master" so that the user does not get -:::- and has to switch back again
    (Avid-internal reference so that I can track this easier: OS-3327)
    Martin
  • Thu, Sep 1 2016 6:30 PM In reply to
    • Munich
    • Posts 15
    • Points 155
    This feature is in development and should be available with an upcoming release.
    I can not give you are release version now as the feature has to go through quality assurance first.
    Martin
  • Mon, Nov 14 2016 10:57 AM In reply to
    • Munich
    • Posts 15
    • Points 155
    Here is a link to the documentation:
    http://resources.avid.com/SupportFiles/attach/ICS/MediaCentral_Platform_ReadMe_V2_8.pdf
    page 18
    Section "Editing"
    “Clip” added to timecode display
    Martin
