Latest post Thu, Jul 27 2017 8:58 PM by G. Pertian. 6 replies.
Page 1 of 1 (7 items)
  • Fri, Jun 19 2015 2:12 PM
    • daktulus
    • Posts 958
    • Points 13,910
    How to get one big single composer window screen
    MC 7
    For effect editing I need a workspace with just one composer window.
    But when I pull the single composer window bigger, the second composer window screen always appears. I just need one screen, not two (to be able to pull the one as big as possible)..
    I remember this was possible in prior versions, is it impossible to have one big single composer window now?
    i7, Nvidia 860M, 16GB RAM, 500GB SSD, MC 7.03. Dell Precision M90, Core2Duo 2.16Ghz, FX1500, SATA 7200rpm, MC 4.05. Dell650, 2.8Ghz, 3 GB RAM, FX500, 5... [view my complete system specs]
  • Fri, Jun 19 2015 3:04 PM In reply to
    Re: How to get one big single composer window screen
    Hi.
    Alt+Source/record Mode will do that.
    cv
    AVID MEDIA COMPOSER 5.5.3. PC. WINDOWS 7, SP1. 64BIT OPERATING SYSTEM. QUICK TIME VERSION 7.6.9. [view my complete system specs]
    Christian Jhonson
    Avid Ambassador
    christianjhonsoon@hotmail.com
  • Fri, Jun 19 2015 8:09 PM In reply to
    • Posts 11,565
    • Points 255,405
    thumbs up Chris!!!!!!
    Nice
  • Mon, Jun 22 2015 12:49 PM In reply to
    Wink
    Christian Jhonson
    Avid Ambassador
  • Tue, Jun 23 2015 12:23 PM In reply to
    • iedjie
    • Netherlands
    • Posts 236
    • Points 2,840
    mmm... if I alt click in one of the monitors nothing happens. (Is also ment to drag subclips to a bin) If I alt click on the source/record editing workspace in the windows tab nothing happens. If I alt press F9, (my keyboard shortcut for source/record editing workspace), nothing happens. What is the trick? (Beside constructing your own workspace with only record monitor in the size you like)
    mobo MSI P55-GD65, CPU Intel i5-750 @ 3.2 Ghz, memory G.SKILL F3-10666CL7D 2x4GB, Videocard Nvidia Quadro FX 3700, PSU OCZ 500MXSP, Harddisks; Crucial... [view my complete system specs]
  • Tue, Jun 23 2015 9:47 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,910
    • Points 70,010
    With the source and record monitor on, drag the bottom left corner or the left edge of the composer window and shrink it down till the source monitor disappears, resize to Your likings dragging the bottom right corner, if You attempt resizing in any other way the source monitor will show up again.
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
  • Thu, Jul 27 2017 8:58 PM In reply to
    Christian Jhonson:
    After searching a lot I finally found this - and it really works (MC 8.8.5)!
    You have to press the ALT key and then click on the SOURCE/RECORD MODE button, which is for instance in the timeline (left edge).
