Latest post Thu, Oct 5 2017 3:17 PM by George Angeludis. 4 replies.
  • Tue, May 12 2015 5:25 PM
    • Felkman
    • Posts 35
    • Points 465
    Can I delete AMA Metadata Folders?
    I have more thna 500 folders and almost 14,000 files in a directory called AMA Metadata Folders inside AMA Management directory. What are these and what happens if I dlete them? What about "Managed AMA Media Folders.xml" ?  Thanks.
    frank
  • Tue, May 12 2015 6:17 PM In reply to
    Re: Can I delete AMA Metadata Folders?
    Managed AMA is helpful in a shared media environment but little use in a standalone system.
    You will lose project association in media tool but that's of little use as the media tool isn't much help for AMA linked content.
    If unsure just rename the root folder so MC can't see it and check. If all good delete.
    I regularly delete them as well as the attic folders.
    T 07581 201248 | E [email protected]
  • Tue, May 12 2015 7:14 PM In reply to
    Pat Horridge:
    Pat do you know if this is true IF you are sending AMA linked timelines via AAF to Resolve?  Thanks
  • Thu, Oct 5 2017 10:09 AM In reply to
    • BenoitM
    • Brussels, Belgium
    • Posts 1,267
    • Points 15,230
    Did this: http://community.avid.com/forums/p/181399/848409.aspx#848409
    and all seems to work fine :)
    MC 20.10 (+Symphony)/BCC2019 12.5.2; BlackMagic Ultrastudio Mini Monitor+Recorder (11.6); DELL Precision 5530 - Intel Core i7-8850H 2.6 GHz - 32 GB RAM;... [view my complete system specs]
  • Thu, Oct 5 2017 3:17 PM In reply to
    If you will not need anything from those AMA linked clips then deleting will do no harm.
    Desktop
    Asus Ζ690 TUF Gaming WiFi D4|i5 12600K|Corsair 128G DDR4|Asus 3060 12GB|Samsung 980 500GB(OS)|2X1TB Samsung 980 RAID 0|W11 Pro
    Laptop
    MSI Katana GF76 11UE (i7 11800H|Nvidia 3060|Crucial 64G DDR4)|W11 Pro
    NLE
    DR Studio 19|MC 2024.2
    VDIM
