Latest post Mon, Jun 29 2015 3:20 PM by Avid. 1 replies.
Page 1 of 1 (2 items)
  • Tue, Apr 7 2015 10:19 AM
    Markers in Logging Mode - Setting Out Point
    I am having trouble setting an out point when creating a marker in the logging pane. By default the columns has an in and an out column; but when you select create marker it doesn't give you an option to set an out point. Avid 7 has spanned markers which allows this.
    Just seems odd that they would have an out column if you can only create markers as an In point. I have attached an image as an example.
    markers
    When you select create marker it automatically passes you onto the Notes area and bypasses the 'OUT' area. Double clicking here does nothing. Is this a column we just have to get rid of? Just it will be the first thing a client asks.
  • Mon, Jun 29 2015 3:20 PM In reply to
    • Joined on Mon, Mar 30 2015
    • Munich
    • Posts 15
    • Points 155
    Re: Markers in Logging Mode - Setting Out Point
    The out column exists so that you can see where a restriction ends.
    Markers in Interplay don't have out-points yet. (Media Composer supports spanned markers but Interplay does not yet).
    If you think the out column is disturbing you can hide it. Click the Pane Menu on the top right of the pane > Add/remove columns.
    Martin
