Latest post Thu, Sep 17 2015 7:46 PM by Leo Baker. 10 replies.
Page 1 of 1 (11 items)
  • Sat, Feb 14 2015 5:46 PM
    • John Mac
    • Posts 184
    • Points 2,465
    AVID FX causing crashes
    Hi
    Since updating to 8.3 Avid constantly crashes whenever I try to ammend or re render Avid FX - does this mean it is no longer totally compatible with Avid and we have to upgrade to Boris?
    Anyone else having same issues?
    John
    MC 8 Windows 7 Pro 64-bit i7 Intel Core 4 cores 3.5 GHz 16 Gb ram Nvidia quadro 4000 Matrox mini 6TB internal connected to SATA III ports [view my complete system specs]
  • Sat, Feb 14 2015 5:57 PM In reply to
    • John Mac
    • Posts 184
    • Points 2,465
    Re: AVID FX causing crashes
    This is really bad. It's affecting pretty well anything I have edited using Avid FX. As soon as I try to open the effect Avid just crashes. Tried duplicating project file and opening in new project. Tried removing render and re render - has only happened since 8.3
  • Sat, Feb 14 2015 6:14 PM In reply to
    • Vilem
    • Joined on Sat, Apr 10 2010
    • Prague
    • Posts 1,442
    • Points 15,825
    Hello,
    I also occurred after installing MC8.3 about 2x crash.
    But since then everything still works properly. (about one month).
    Avid FX I use quite often.
    Regards
    V.
    AVID MC2021.12, HP Z620 - 2 x Intel Xeon E5-2620, Quadro P2000 - driver 461.72, RAM 48GB - DDR3, BM Intensity Pro 4k - 12.1, W10 - 64bit Professional... [view my complete system specs]
  • Sat, Feb 14 2015 6:47 PM In reply to
    • John Mac
    • Posts 184
    • Points 2,465
    Seems Boris have us by the short and curlies as I didnt feel I had any option but to upgrade to Red 5.5 which I have now done in desperation. Everything now works fine.
  • Fri, Aug 21 2015 5:21 PM In reply to
    • Mott441
    • Posts 5
    • Points 65
    My avid fx crashes constantly. I don't understand...Avid uses this plug-in and even names it "AvidFX" but yet consistently crashes. What does AVID have to say about this problem and is there a cure?
  • Fri, Aug 21 2015 6:18 PM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 4,816
    • Points 63,165
    Mott441:
    What versions of AvidFX and MC are you running?
    You've given us nothing in terms of your system specs either (see how mine are entered into my profile). We often rely on system specs to help identify potential issues when answering posts like this.
    FWIW - I migrated to Boris RED 5.5 since MC 8.x because I was having issues with AvidFX in MC 8.x (AvidFX was from MC 7.x). I liked the improvments in RED 5.5 and the $299 update fee was reasonable at the time (for my purposes).
    MC 2021.6 | QT 7.7.9 | Continuum 2021 | Sapphire 2021 | Mocha Pro 2021 | Titler Pro 7.7 | Windows 10 Pro x64 (21H1) | System: Asus x299, i9-7940X (4.1GHz... [view my complete system specs]
    Steve
    ______________________
    www.nelliedogstudios.com
  • Thu, Sep 17 2015 12:16 PM In reply to
    • Peter Dungen
    • Netherlands
    • Posts 5
    • Points 60
    I Updated to MC 8.4.1, start up ok, media playing ok, but playing in timeline LUT FX: Avid crashed , windows crashed seriously to only option manual reboot. Other projects same. Downgraded windows system reset to earlier system point.
    AVID start up MC 8.4.0 all ok except does not play earlier color FX. Had to remove all color fx but crashes on new color FX.
    How can I repair AVID to play LUT FX and use color FX in the same timeline?
    (errors at Intell RST at start up after reboot, manually restarted)
    System HP Z800 2x six core X 5650 RAM 24Gb / Bios 3.20/ NVIDIA Qudro 4000 FW 347.52 / Windows 7/ AJA express i/o /
    HP Z840 2x 14 core bios 2.48 / RAM 32Gb / W10 / Quadro M4000/PCIe/SSE2 version = 4.6.0 NVIDIA 430.64 BM Mini monitor 4k/ HP Thunderbolt 2 / MC 8... [view my complete system specs]
  • Thu, Sep 17 2015 12:52 PM In reply to
    • Leo Baker
    • Joined on Wed, Oct 5 2011
    • Posts 494
    • Points 5,805
    I will test rendering AVid fx to see if I can crash 8.4.1 on my Windows setup. Noticed when I dragged the Avid FX Filler effect into a clip, I got Avid sttopped working crash. Tried again it wokred, then a few more attempts, opening Media Composer, the new test project and it randomly crashed Media Composer dragging that effect onto a DNXHD clip.
    MacPro6.1 Late 2013 Intel Xeon 12-Core 2.7GHz 64GB RAM AMD FirePro D700 6GB OSX Mojave 10.14.6. Media Composer 2020.5, Pro Tools Ultimate 2020.5, Avid... [view my complete system specs]
  • Thu, Sep 17 2015 1:38 PM In reply to
    • Peter Dungen
    • Netherlands
    • Posts 5
    • Points 60
    Thank you Leo for your quick response.
    In the mean time I saw that AVID supports a newer NVIDIA driver so I upgraded and rebooted again.
    Than I consolidated my timeline which reported several audio and video codecs out of project..
    I left them for granted and played the consolidated timeline without problems. Also FX and color FX. For now it seems that it is working again. I will test the problem timeline later because of a deadline. I will keep you posted.
    Thanks again, it's good to know to have fine collegues around the world.  ;-)
    Peter
  • Thu, Sep 17 2015 1:58 PM In reply to
    • Leo Baker
    • Posts 494
    • Points 5,805
    You are welcome Peter, I don't have access to the version 8 as I am not home yet. I will be later tonight and I'll check the render and gpu Nvidia GPU driver that I am running. I am certian I am using the updated Nvidia card for Avid. Leo
  • Thu, Sep 17 2015 7:46 PM In reply to
    • Leo Baker
    • Posts 494
    • Points 5,805
    Hello Peter,
    I added a dnxhd175x 23.976p video clip onto the AVid timeline and added from efects Avid FX Filler onto the clip direct on the timeline. I added an effect, then did export movie quiicktime on my Windows pc setup same as source and no crash.
    Avid FX 6.2.0
    Nvidia Graphics 347.52
    Avid Media Composer 8.4.1
