Latest post Mon, Feb 16 2015 5:08 AM by Ervz Tia (Tikboy). 6 replies.
Page 1 of 1 (7 items)
  • Fri, Feb 13 2015 6:07 AM
    Recommended GPU For Avid & Adobe
    Hello!
    We are upgrading our current system: MacPro (mid2010)/8-core/ATI Radeon HD 5770. I'm recommending more RAM and new GPU. I was looking at Avid's document but there's very limited GPU choices on the list. What would you recommend?
    - Do I even need to? I mean the stock ATI is working fine with editing and some AfterEffects
    - If I do, WHAT would you recommend (mid-range/budget)?
    Some items from OWC
    Qualified Apple Mac Systems for Media Composer
    Ervz Tia | Video Productions
  • Fri, Feb 13 2015 7:12 AM In reply to
    • Mondo
    • Sydney Australia
    • Posts 1,626
    • Points 18,640
    Re: Recommended GPU For Avid & Adobe
    Ervz Tia (Tikboy):
    THe 5770 is OK - it's a budget card and it won't be doing a lot of the heavy lifting for you. You'd certainly notice an improvement with the cuda cores on an NVidia GTX 760 or 960 (the "60" series is generally a good option ofr a budget build) with a decent amount of VRAM (provided they have a Mac driver for your OS) , but I think your MAc would only be specced PCIE-Rev 2 and most modern cards are Rev 3. They'll work but probably not optimally as Rev 3 nearly doubled the bandwidth per lane.
    So its pretty much a suck it and see scenario. They'll certainly work better and your Adobe apps will definitely take advantge of the increased processing power. See if anyone chimes in with practical experience on your MacPro model.
    John
  • Fri, Feb 13 2015 8:24 AM In reply to
    Thanks Mondo!
    How about the Nvidia GTX 580 3 GB? >> macvidcards.com/store/p17/Nvidia_GTX_580
    Have you tried buying from them? >> macvidcards.com/
  • Fri, Feb 13 2015 12:17 PM In reply to
    • Tiger_XP
    • Joined on Fri, Feb 2 2007
    • California
    • Posts 465
    • Points 5,170
    Ervz Tia (Tikboy):
     Go here ( http://forums.macrumors.com/forumdisplay.php?f=1) to read some of his posts and others pertaing to GPU's. He is a GPU Guru for sure!
    MacPro 2008 3.1 | 34GB Ram | Quadro 4000 980ti 960| MC 8.10 | OS 10.6.8 10.13.6 | MOTU HDX-SDI | ATTO R644| LaCie 324 [view my complete system specs]
  • Fri, Feb 13 2015 12:59 PM In reply to
    • CinéMatica
    • Joined on Tue, Jun 24 2014
    • Belgium | Europe
    • Posts 215
    • Points 2,525
    Hello Ervz Tia (Tikboy),
    About a six months ago I also was looking to update my Mac Pro with more RAM and a better video card. I have replaced the original video card (ATI 4870) that came with my Mac Pro 4.1 (early 2009) with a EVGA GeForce GTX 680 Mac Edition. Never had any problems with it.
    Greetings,
    Ivan
    (Avid 1) HP Z840 | 2x 18 Core Intel Xeon E5-2699v3 / 2.3GHz 35MB | 128GB PC4-17000P 2133MHz / 8x 16GB DDR4 | NVIDIA Quadro P4000 / 8GB GDDR5 / 4x DP 5K... [view my complete system specs]
  • Fri, Feb 13 2015 8:07 PM In reply to
    • Isaac T.
    • Joined on Mon, Jan 9 2006
    • New York / Knoxville, TN
    • Posts 759
    • Points 8,990
    +1 for the GTX 680:
    http://eshop.macsales.com/item/EVGA/02GP43682/
    OWC might still have a rebate for turning your old video card.
    Also, Avid won't benefit as much from the GPU as Adobe apps. I have one, night and day difference with After Effects.
    Mid-2010 Mac Pro • 2018 MacBook Pro [view my complete system specs]
  • Mon, Feb 16 2015 5:08 AM In reply to
    Awesome! I'm looking at it. We're planning to transfer the HD5770 to another older MacPro.
    Macvids have it cheaper>> GTX680
