Hey I have a project where I want to add some sharpning to the videos. Ive done some CC work so instead of having to step in to apply a sharpning filter to each individual clip, should I mixdown then add the sharpen filter? Would this affect quality? Should I sharpen mixdown then do the CC work? In what way would some of you handle this?
My opinion is that you should add the sharpen filter on top of the color correction for each clip. One size may not fit all. Some shots may need more, some less.
Jef
Jef Huey
true was just trying to avoid the extra work...
Sharpen filters can quickly make an image worse than it started. No real way to avoid a shot by shot pass.
Its a Boris unsharp mask? Can it not sit on the layer above?
Ultimate 2022.12.1, Blackmagic Intensity Pro, WIN 11 on 7000Mbps M.2 SSD, Nvidia Quadro P4000, Asus Pro Art Z690 i9 12900k 5.0 GHz, 8TB M.2 SSD - its nippy!
