Hi
May I ask:
1- how can I change my wave scale in audio track? most of them is so higt and they are not recogniseable and I need to make them smailer!
2- What is the easiest and fastest way to ajust the audio level? put keyframe and ajust one by one is not a good way I think or it is what is your workflow?
3- when I select wave form for a track to show just when I select a part of my project it works and show me just that part! how can I set to see all my audio in a track with wavefrom?
Many thanks
1.) That's a limitation of MC. I am hopeful they will fix it at some point, but sometimes the waveforms are so intense they are useless to try and edit to.
2.) Personally, I prefer clip-based changes instead of automation, but I don't do high-level audio...I leave that to other people who do the mixes. You just change the volume in the mix tool per clip and add edits with dissolvbes if you need to transition levels.
3.) Settings > Timeline > Display...uncheck "Show Marked Waveforms"
Alireza Vasefi:1- how can I change my wave scale in audio track? most of them is so higt and they are not recogniseable and I need to make them smailer!
1. Enable the track selectors of the track(s) whose waveforms you want to resize
2. Press alt/command/k to reduce the waveform size, alt/command/l to increase it
MikeyB: Alireza Vasefi:1- how can I change my wave scale in audio track? most of them is so higt and they are not recogniseable and I need to make them smailer! 1. Enable the track selectors of the track(s) whose waveforms you want to resize 2. Press alt/command/k to reduce the waveform size, alt/command/l to increase it
You learn something new every day!
Alireza Vasefi:when I select wave form for a track to show just when I select a part of my project it works and show me just that part! how can I set to see all my audio in a track with wavefrom?
Timeline Fast Menu > Audio Data > Waveform
That should turn them on for all tracks.
Kevin Klimek: MikeyB: Alireza Vasefi:1- how can I change my wave scale in audio track? most of them is so higt and they are not recogniseable and I need to make them smailer! 1. Enable the track selectors of the track(s) whose waveforms you want to resize 2. Press alt/command/k to reduce the waveform size, alt/command/l to increase it You learn something new every day!
Hi Kevin
Yes, exactly ;) I try hard
It is the best time and my fun of my life to learn something new every day :P
Thank you very much it was very helpful specialy No. 3
Thanks for great short cut it is very useful for me
