Latest post Wed, Oct 28 2015 1:41 AM by othila. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Sat, Oct 11 2014 4:12 AM
    Audio Glitch Problem - MC8.1.0
    Hello,
    Have just upgraded MC7 to MC8.1.0 - I am experiencing a significant audio issue at the start of every audio clip.  I usually use audio key frames to ramp audio up to full level, and dip accordingly where neccessary.  However - in MC8.1.0 when I set the initial audio level at the start of a clip to 0 (no audio - not 0dB)  and then ramp it up to any level, on playing the clip the first frame plays at full level.  ie - there is a nasty glitch at the front of every audio clip.
    I have tries using the audio faders on the head of each clip - drag this all the way down to -dB and it'll still play one frame of full level before it recognises the level should be 0.
    There is therefore a single frame audio glitch on the head of every one of my audio clips - significantly problematic if mastering a broadcast edit on Monday - any help or thoughts gratefully appreciated.
    Thanks  Tb
    Current System Spec:  Mac OS 10.9.5 on a 2.2GHz 8GB MacBookPro with AMDRadeon
  • Sat, Oct 11 2014 4:17 AM In reply to
    • jkeditor
    • Joined on Tue, Aug 20 2013
    • Posts 10
    • Points 110
    Re: Audio Glitch Problem - MC8.1.0
    I am having the same problem running MC 8.1.0 on 2.3GHz 16GB RAM MacBook Pro running OS X 10.9 - even when I put a dissolve at the front of an audio clip I get this audio glitch.
    Need to get this sorted quickly as I'm also mid-project with a tight deadline and an angry client!
  • Sat, Oct 11 2014 7:14 PM In reply to
    Me too... Roll back to 8.0 and your problem will go away.
    Does anybody at Avid test these releases?
    FACT: Most of Hollywood is still using V5.5. How can Avid survive when most of their high end users are on 4 year old software because subsequent releases are too unreliable? I applaud Avid for looking to the future with many exciting ideas but you need to fix these kind of bugs quickly or you are doomed and I will have to learn another more reliable application. I have been using this software for 23 years and will be very sad to see this company fail.
    Multiple Mac systems, MAC Pro, MacBook Pro's, OS Mojave, AJA IO 4K, T-Tap. [view my complete system specs]
  • Sat, Oct 11 2014 7:34 PM In reply to
    • othila
    • Joined on Thu, Sep 29 2011
    • Posts 206
    • Points 2,550
    I mentioned that same problem here on the fourms months ago but had no response, this audio glitch has rendered MC8.1 as unusable.
    Avid Media Composer 8.3.1 Matrox MX02 on MacPro4,1 Quad-Core Intel Xeon 2.66 GHz, Memory: 16 GB, OS 10.8.5, NVIDIA Quadro 4000 [view my complete system specs]
  • Sun, Oct 12 2014 10:39 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 754
    • Points 9,415
    +1 Same - but not all the time.  Cant see a pattern
    MC8.10 Win 7 64 with Dongle, Dual 10 core Xeon, Quadro K4000, Adaptec RAID 5-8x3TB, External TB2 4x3TB, 64G RAM, BM Intensity Pro 4K. NewBlue Titler 6... [view my complete system specs]
    Vote 1 - Dongles.
    UME an old engine, now with 4K, mags and furry dice....
  • Sun, Oct 12 2014 4:03 PM In reply to
    • Marty
    • Joined on Sat, Dec 3 2005
    • Berlin, Germany
    • Posts 979
    • Points 11,590
    all different setups in various editing suites. my own: MC 2021.9, OSX 10.14.6, iMac (Retina 5K, 27-inch, 2019), 3,6 GHz Intel Core i9, 64GB RAM, Radeon... [view my complete system specs]
    www.film-editing.de
  • Mon, Oct 13 2014 12:12 AM In reply to
    • bastian
    • Joined on Fri, Jan 20 2006
    • Brisbane, Australia
    • Posts 69
    • Points 865
    Same problem on both my PC Avid qualified sytems, recently upgraded from 7.0.4 to 8.1.
    Also constant AMPI subsystem error when trying to export wav or QT ref files with wav after working on audio for a while - have to restart Avid.
    Loud pops and crackles when scrubbing through the time-line with audio scrub on - legend communication underun error briefly pops up in record monitor
    Audio suite plugins - have to hit render multiple times before they actually show up as rendered...
    Avid 1 - Lenovo D30 & Nitris DX, Win 10 Pro, MC 8.9, Asus GeForce GTX 1050Ti, 32gig ram, Proavio EB800MS 16TB array & LSI MegaRaid HBA :: Avid... [view my complete system specs]
  • Mon, Oct 13 2014 1:08 AM In reply to
    • Tom Pearson
    • Joined on Thu, Mar 1 2007
    • Los Angeles CA / Dallas TX
    • Posts 2,216
    • Points 23,845
    I have just tried it on my mbp with ama'ed footage and no glitches at all what kind of files were they?? mine were P2 4 track and canon C300 2 tracks  also might not matter but I cut in the clips from larger clips are you doing that or is it the full clips?
    Mac Pro 3.5 gig 6 core 64 gig ram D700 radons with ssd os drive with a 20 tb raid, Artist Mix and Artist color Artist control [view my complete system specs]
    Tom Pearson
  • Mon, Oct 13 2014 10:00 AM In reply to
    • Marty
    • Berlin, Germany
    • Posts 979
    • Points 11,590
    I have a similar problem with audio dissolves & eq effects in MC7.
    I get a short crackle / clicking sound on the 1st frame of the dissolve during realtime playback. It seems that the audio dissolve isn't working on the 1st frame the same way it isn't working on the clips with auto gain.
    http://community.avid.com/forums/t/130287.aspx
    www.film-editing.de
  • Mon, Oct 13 2014 5:14 PM In reply to
    I'm having the exact same issue with this at the moment meaning it's impossible to edit audio! I've been adding dissolves, key frames, using faders but nothing gets rid of the full volume first frame glitch on the audio. It's embarrassing when playing back to a client as it's a problem i'm unable to explain. Anyone at Avid have any news on sorting this out, and quickly?
  • Tue, Oct 14 2014 12:25 AM In reply to
    • bastian
    • Posts 69
    • Points 865
    Moderators - can we get this escalated, more than three people are experiencing the same problem.
  • Tue, Oct 14 2014 12:28 AM In reply to
    Sorry...I did escalate it this afternoon.  Forgot to post it in the forums.  Will report back when I hear something.
  • Tue, Oct 14 2014 1:10 AM In reply to
    • bastian
    • Posts 69
    • Points 865
    Thanks Kevin - looking forward to hearing the result.
  • Wed, Oct 15 2014 11:05 AM In reply to
    Thanks Kevin - a look into this specific 8.1.0 audio clip issue originally posted would be great - it's proving very problematic laying off to tape with this issue - thanks
    T
  • Mon, Oct 20 2014 7:35 PM In reply to
    Hi all,
    This issue has been fixed in Media Composer | Software v8.2!
    Readme and What's New:
    http://avid.force.com/pkb/articles/en_US/readme/Media-Composer-Software-8-0-Documentation
    Get this new version through the Application Manager or http://esd.avid.com
    Read all about this new version, in my Avid Blog post:
    http://www.avidblogs.com/media-composer-software-background-rendering-now-available/
    Wim
    Social Media Manager at Avid
    Editor-in-Chief avidblogs.com
    Got a great story to tell for #TimelineTuesday?
    Want to share a Media Composer Tutorial on #TutorialThursday?
    Contact me!
    Twitter: @editorbelga
    Facebook: fb.com/editorbelga
