Latest post Fri, May 15 2015 9:06 AM by MikeyB. 3 replies.
  • Fri, Sep 19 2014 12:46 PM
    • SilvaEdit
    • Joined on Wed, Nov 3 2010
    • Posts 111
    • Points 1,335
    Drawing Curves in Animatte & Deleting Keyframes MC 7.0.4
    Hi all
    Is it me or can you not draw curves when using the Poly Tool in the Animatte effects editor anymore? You seem to be able to curve the first point somewhat but thereafter they remain straight. After finishing your matte you can click on the reshape tool and adjust curves to each point but I would like to be able to do it on the fly as before.
    I'm sure you used to be able to hold ctrl or cmd (mac) when you were adding points to create a bezier curve?
    I also can't seem to delete keyframes easily on my effects? I have to keep tapping the delete key and it takes a different amount of taps each time to finally remove the keyframe. It seems to be more difficult wehn it is just a single keyframe on a 3D warp.
    Any info would be much appreciated.
    S
  • Fri, Sep 19 2014 1:52 PM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 573
    • Points 7,140
    Re: Drawing Curves in Animatte & Deleting Keyframes MC 7.0.4
    Yes, this seems to have got broken in recent versions. It's still a problem in v8.1 too.
    As a workaround, you can go back to your control points and convert them to beziers afterwards by Option/clicking them, but it's a pain to have to do so.
    I've not noticed keyframe deletion being a particular problem. Are you trying to delete them from the Effect Editor or from the Effect Preview Window (the Monitor)?
    MacBook Pro 15" 2016 2.7GHz i7 Radeon 455 [view my complete system specs]
  • Thu, May 14 2015 5:31 PM In reply to
    • JDerringer
    • Joined on Wed, Mar 26 2014
    • Posts 4
    • Points 70
    Hey Guys,
    I'm also experiencing this on various versions of Symphony 7 and MC8. I can't find anything from Avid acknowleding this as a bug, so just checking in to see if anyone has found either:
    A. A version (7 or above) where this is fixed
    OR
    B. A setting/fix for this within the current version.
    Thanks in advance.
    JD
  • Fri, May 15 2015 9:06 AM In reply to
    • MikeyB
    • Edlesborough, UK
    • Posts 573
    • Points 7,140
    I think I remember reporting it at the time. It's certainly fixed in the latest version, if that's any consolation.
    Meanwhile, the Curve tool is often a reasonable alternative, as it creates a lot fewer 'spurious' control points than it used to.
