Latest post Tue, May 13 2014 10:05 PM by Pat Horridge. 2 replies.
  • Mon, May 12 2014 7:41 PM
    • anikvogul
    • Joined on Mon, May 7 2012
    • Posts 6
    • Points 100
    Exporting Sequence for Rogers TV, interlaced problem and big files
    Hi!
    Anyone knows how to export for Rogers TV(broadcast), I have been assined to submit the MOV file, and I did export it as SEND MOVIE TO QT, or SAS, but I still get interlaced problem, the file is huge and loosing quility. I don't have any squeeze programs only QT, Avid MS 6.
    My project is 16:9, 29.99i fps, since I filmed on Sony PD 170, tape.
    Thank you!
    Filed under: , ,
  • Tue, May 13 2014 8:31 PM In reply to
    • mBlaze
    • Boston
    • Posts 427
    • Points 4,950
    Re: Exporting Sequence for Rogers TV, interlaced problem and big files
    What type of interlace problems are you running into, reversed fields?
    Avid Media Composer 7.0.3 on MacBook Pro 2.5GHz Intel Core i7 [view my complete system specs]
    James Burke
    Video Producer / Editor / Designer
    blog.DVfanatics.com
  • Tue, May 13 2014 10:05 PM In reply to
    If your source is interlaced and your project an i project then your export will be interlaced. and if you play that QT movie you would expect to see interlacing artefacts. Because you are watching it on a progressive computer display.
    Field reversal will cause the palyback to stutter really back. Like bad progressive.
    The file size will be determined by the resolution you have in the sequence if you do a same as source export. So make sure the sequence is transcoded to the quality you need first.
