Latest post Thu, Jun 23 2016 8:01 PM by Scott_Freeman. 7 replies.
  • Tue, May 6 2014 1:16 AM
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 3,841
    • Points 46,370
    Sony F55 proxy to 4k online relink issue
    A client shot on Sony F55 in XAVC 4k.  They chose to offline using the XDCam Proxy's which are generated at the time of shooting.
    They used Frame Flex to reframe the material on certain shots.
    Now that the cut is locked, we need to relink to the 4k XAVC master clips. Here is where the problem starts.  The issue is that the Proxy files have an additional bit of text at the end of their Source Name = "S03" as well as being in a different folder.
    We have tried many different methods to make this relink and nothing has suceeded so far.
    Has anybody succeeded in such a workflow?  If so, could you share?
    Jef
    Jef Huey
  • Tue, May 6 2014 3:40 AM In reply to
    Re: Sony F55 proxy to 4k online relink issue
  • Tue, May 6 2014 12:47 PM In reply to
    • jef
    • Maryland
    • Posts 3,841
    • Points 46,370
    Hi Job,
    Forgot all about that blog.  Giving it a try right now.  Thanks.
    Jef
    Jef Huey
  • Tue, May 6 2014 4:46 PM In reply to
    • jef
    • Maryland
    • Posts 3,841
    • Points 46,370
    Well that work just fine!! Thanks.
    The big thing that it pointed out to me which none of us here really had considered is that the Original and Target areas of the relink tool are related.  We had considered them an "either / or" type of tool.  I am now rethinking the whole relink tool.
    I do not believe the Avid help files really show how to use that area of relink.  At least I could not find any discussion of it.  And this situation I had shows how powerful it is, when you understand the tool.  Which I did not.
    Now all I have to do is deal with some ugly FrameFlex issues in this same project.
    Cheers,
    Jef
    Jef Huey
  • Sat, Mar 14 2015 5:37 PM In reply to
    • chandre
    • Posts 2
    • Points 30
    Hello JEF,
    I'm a french editor and I've got the same problem like you. I believe it.
    I edit with proxy from Sony F55 (XDCAM50 HD) with ama. I don't succeed in relinking my sequence with 4k (RAW) (with AMA too). I read your post and from what I understand, you succeed it ! :-)
    Can you explain how did you make it, please ? Which Settings are you choose in the Relink Window ?
    Sorry for my english...
    Thanks a lot
    Alex
  • Sat, Mar 14 2015 7:43 PM In reply to
    • jef
    • Maryland
    • Posts 3,841
    • Points 46,370
    Hello Alex,
    That was awhile ago, so my memory is vague.
    Did you read the following:
    http://24p.com/wordpress/?p=181
    That was the basis of my solution I believe.
    Try it and report back.
    Good luck,
    Jef
    Jef Huey
  • Sun, Mar 15 2015 5:13 PM In reply to
    • chandre
    • Posts 2
    • Points 30
    Hello,
    I read it again and i don't succeed.
    First I haven't got the same problem that this blog. The filename between 4k and and XDCAM proxy is the same (when i watch the "Source File" Column). Nevertheless, I try it with the same setting (without ignore characters) and MC (8.3) don't relink with my 4K (raw with AMA)...  I try too after consolidating XDCAM... Same problem...
    If you can help me... :-)
    Thanks a lot
    Alex
  • Thu, Jun 23 2016 8:01 PM In reply to
    I hope this is helpful for using the Avid Media COmposer relink command when the conform is Sony 4K XAVC from XDCAM Proxy offline seqeuence.
    Removing the end charcters in the relink command. Here are some example settings that are working for me.make_metadata_identifier_match_relink_ignore_characters_after_last_occurrence_s02_for_reconform_sequence_from_offline_xdcam_proxy_to_4k_xavc.jpg
    http://www.metadatalinks.com [view my complete system specs]
