Latest post Thu, Feb 13 2014 1:20 AM by AndrewAction. 5 replies.
Page 1 of 1 (6 items)
  • Wed, Feb 12 2014 9:17 PM
    ICONS FOR KEYBOARD DESIGN
    Hello,
    I'm really not sure where to post or ask about this.... but I thought poeople here might be able to point me in the right direction.
    I want to create my own sticker set for my keyboad that has my personal mapped settings. (I don't use the standard setting so I can't just buy one). I've been looking for the Avid media composer icons in vector format everywhere and can't find them.
    Can some one help me find sothing I can use to do this?
    Marian
  • Wed, Feb 12 2014 9:32 PM In reply to
    Re: ICONS FOR KEYBOARD DESIGN
    If you drag-and-drop the Media Composer application onto Preview, it should open a Preview window that shows you quite a few icons, though they are unlikely to be vector-based.
    8-core Nehalem Mac Pro with Pro Tools|HDX v10.3.8 and DeckLink HD Extreme 8-core Nehalem Mac Pro with Symphony Nitris DX v7.0.3 12-core Westmere Mac... [view my complete system specs]
    Jonathan S. Abrams, CEA, CEV, CBNT
    Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.8)
    Chairman, NY section, Audio Engineering Society
  • Wed, Feb 12 2014 10:37 PM In reply to
    Yeah, that worked but the icons are very small and since they are not vecotr they get really blurry...
    Thanks for the tip!
  • Wed, Feb 12 2014 10:42 PM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 154
    • Points 1,880
    http://lazybrowndog.net/avid-keyboard/
    Try this!
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Thu, Feb 13 2014 12:42 AM In reply to
    Thanks this is a good start but lots of the mappable items are missing... I wish avid had them somewhere to download...
    Thanks for the help
  • Thu, Feb 13 2014 1:20 AM In reply to
    Another work intensive option
    With Avid running open the Command Palette and click through the tabs taking a screenshot of each tab. Open in the screen shots in Photoshop. Select each desired icon and copy it. This will make a new layer with just that icon on it. Turn off the visibility on all layer except the one with a desired icon and export it as an image. Repeat for all icons
    For Vectors if you have Illustrator open it and Auto Trace these images.
    In the way distant past I thought there was a pdf with the Avid icons. If you can find that then opening it in Photoshop or Illustrator should get you something usefull to start from. A quick search on my system does not find that pdf.
