Latest post Thu, Jan 9 2014 9:19 PM by oze. 29 replies.
Page 1 of 2 (30 items) 1 2 Next >
  • Tue, Dec 17 2013 8:28 AM
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    MX02 Mini just died, this could be good news . . .
    After about 5 or 6 years of use, my MX02 Mini Max seems to be on the blink - litterally. The red light is flashing and there is no signal. I think it has died. As i have been extremely disappointed with the sluggish, stuttering performance combination with MC V6.0 onwards, I see this as potentially good news. For years I used to always be on the current version of MC but this has been the main reason I have not botherd to stay current and upgrade to V6.5 or 7. What's the point? A few new features but year after year the same stuttering problem continues. A lot of the time I disengage the Mini and enjoy MC the way it should be, but I do need HD monitoring, so I have persevered with it, even have looked at FCPX as an alternative on some jobs - at least it's responsive in a way MC has not been in years (Take note Avid!)
    So now, the question is . . . what should I replace it with. I know there is a bunch of new boxes out there with thunderbolt support etc. I anticipate continuing with my current Mac Pro for quite a while, so the the thunderbolt thing is not that big, but I guess it is important to have an eye on the future as things are very rapidly heading that way and someday soon most of us will end up with a big, black cylinder on our desktops with thunderbolt everything . . .
    So what would you reccomend for someone who mostly does TVC's and corporate work and does not need SDI or other broadcast connections, bit most of all is RESPONSIVE and 100% works with MC without any stuttering or lag . . .
    Much appreciate all thoughts and advice Big Smile
    2017 27" iMac i7 4.2, 2TB PCI memory, 64GB RAM, OS 10.13.6, MC 2018.10 [view my complete system specs]
  • Wed, Dec 18 2013 12:14 AM In reply to
    Re: MX02 Mini just died, this could be good news . . .
    I have an Aja I/O express and a Kona 3 that I bought second hand.
    Both perform flawlessly.
    Perhaps pick up a S/h Kona 3 to use until you shell out for the black wastebin when you will need thunderbolt i/o.
    http://www.ebay.co.uk/itm/AJA-Kona-3-PCI-Express-with-Cables-/121204522221?pt=LH_DefaultDomain_0&hash=item1c385a3ced
    My 2 halfpennies...
    Symphony 2018.12.13 Mac Pro 2x2.66 6-core 32GB Ram Aja Kona Lhi. MC 2018.12.13 OS 10.13.4 Mac Pro 5.1 2x2.97 6-core 32GB ram Aja I/O express, SNS SANmp... [view my complete system specs]
  • Wed, Dec 18 2013 1:48 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 4,020
    • Points 48,520
    Agree on an eBay Kona 3.  It is a tank.
    Jef
    Avid DS 11.0.2 R.I.P | MC "Well, it depends ..." 2021 iMac w Big Sur [view my complete system specs]
    Jef Huey
  • Wed, Dec 18 2013 2:27 AM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    Thanks David and Jeff, does it need to go in any particular slot in the MP . . ? Also, I guess I would need to buy an SDI to HDMI converter . . . and it definitely solves the sluggish scrolling and general sluggish response of the interface? No lag?
  • Wed, Dec 18 2013 2:53 AM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    The only major issue is that it eliminates any opportunity to be mobile with my MBP - that might be a deal breaker . . .
  • Wed, Dec 18 2013 9:02 AM In reply to
    Mobile? Then I/o Express. Sometimes seen on E-bay, but pricier.
    (-If the MBP has an express slot)
    That will also give you HDMI, but your monitor will probably be happy with RGB from a Kona, which is how I feed the Panny.
    (HDMI clips sub blacks so setting up with pluge is not possible)
  • Wed, Dec 18 2013 11:38 AM In reply to
    • pierreh
    • Paris, London
    • Posts 1,285
    • Points 15,695
    I was looking at the IO Express - someone was selling one recently, as well as a Matrox Mini. When I asked about lag and responsiveness of the interface, he said they were equally as bad, with the Matrox slightly better... So I stuck to my Matrox.
    But would be happy to hear other opinions.
    It seems that a lot of the slugginess of those third party boxes also comes from Media Composer deals with Open i/o and the way it sends info frame by frame. Someone with insider knowledge might chime in and give us more technical explanations.
    - Work: MacPro 2010 3.46Ghz 12 Cores 48Gig RAM, Mojo DX, 10.14.6 - Home: MacBookPro 2.5Ghz quad-i7, 16Gig Mem and SSD OSX 10.11.6 [view my complete system specs]
  • Wed, Dec 18 2013 7:04 PM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    I bought that Kona 3 and it's shipping now, hopefully it will be a goody. I'm currently using a 21" 1080 computer monitor so may have to look into either one that has RGB inputs or a converter of some kind.
  • Wed, Dec 18 2013 7:41 PM In reply to
    Did you get the break out panel?
    A BM HDlink HDSDi to HDMI box has worked well here for about 6 years now. Only problem was their power supply and flimsy connector to the unit. Hardwiring a different power supply solved that
  • Wed, Dec 18 2013 7:51 PM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    Thanks Andrew, no breakout panel, it's basically just for monitoring only. Do you have a link for that BM product. I had a quick look at the site and couldn't see it . . .
  • Wed, Dec 18 2013 9:54 PM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 154
    • Points 1,880
    Your seller is wrong. For me as a owner of Macbook Pro the largest lag in Avid 6.5 was with Matrox Mini which a have since Avid 5.0.
    When I tried on Mac pro Blackmagic Intencity Pro the lag was little slighter. But with AJA Io Express my Avid is flying!!!
    I have selled my Matrox with without hesitation. As I know the smallest lag only on AJA devices.
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Wed, Dec 18 2013 10:10 PM In reply to
    Link to page  Go to page 2 and Product SDI/HD-SDI/3G-SDI to HDMI with 2 ch AES/EBU or analog audio. (update on the old one I have) shows at less than $300
  • Fri, Dec 20 2013 7:42 AM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    Thanks Andrew, I picked one up today from Protel in Auckland - should arrive on Monday. What's the deal with audio? I guess it's sourced from the MacPro minijack . . ?
  • Mon, Dec 30 2013 11:38 PM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    Installed the Kona 3 card was easy enough but the sluggishness remains as it did with the MX02 Mini. This is very dissapointing . . .
  • Tue, Dec 31 2013 2:44 AM In reply to
    • oze
    • New Zealand
    • Posts 575
    • Points 6,860
    An even bigger disappointment is that the Kona 3 card appears to have some pretty severe chroma tearing and is no good. So much for E-Bay purchases. I guess I should have known better . . .
