I have recently upgraded to MC7.2 on a Mac and use G-Tech G-Rain external hard drives as my external media drives, as I have done for years - I am currently working on an 8TB drive that is for an ongoing year long project that currently has about 1TB of HD media imported/transcoded from XDCamHD as XDCam50, or from HDCam at DnxHD120
I am constantly having an issue after editing for about over an hour - I cannot render any effects, import any media or digitise anything - I get several different errors, all linked to the Creating Folder. I have 3 MXF files in my Media Files/MXF on the external drive, and MXF3 holds the Creating Folder.
For example - just now I have tried to render some effects and get: "Exception: 'DISK_UNIX_ERROR' and names MediaFiles/MXF/3 as the source of the problem - I then cannot delete the "Creating" Folder in the file MXF3 until I re-boot the system. So I have to quit Avid, restart, delete the Creating Folder, open Avid again, and off we go - until next time.
I have to go through this process many many times a day - it's painful.
Does anyone else experience this issue...? Can anyone shed any light on why this may be happening - it's wasting a lot of time, and has become rather tiresome...! It has been happening since i upgraded a couple of months back (uninstalled previous version, new settings etc etc)
Let me know, thanks
T
It could be a fauty or corrupt File System. Run "Repair Disk" from within Disk Utilities on that volume.
"There are few technological barriers. You can fix almost anything if you throw enough money at it."*******************************Randall L. Rike, ACI, ACSR Mac*Win*Unity*ISIS*DSSystems Engineer @ BET Networks [a Viacom company](wwld)
Hi Randall,
Thanks for the prompt response - I should have mentioned that I had already gone down that route - I have just run a Repair Disk from the Disk Utility again to make sure and it comes back with a green "The volume appears to be OK" - So am guessing this is not the issue. Any other ideas very welcome....
Many thanks
What is the full path to your media drive folders?
You use "files" and "folders' a bit interchagably...are you saying you have 3 numbered FOLDERS in your MXF folder?
You can try renaiming these folders to different numbers, and any new files will be be created in a new "1" folder the system will make.
Hi Kevin,
Apologies for the confusion - posting while trying to edit..!
The full paths are:
External Hard Drive / Avid Media Files / MXF / 1
External Hard Drive / Avid Media Files / MXF / 2
External Hard Drive / Avid Media Files / MXF / 3
So there are currently three different folders holding media folders, numbered 1 to 3 - they all have database files, which I have also deleted and re - scanned on several occassions - the folder MXF / 3 currently holds the Creating folder
Hope that clarifies - any thoughts...?
Tb
That would imply folders 1 & 2 are now filled to Avids working capacity and media creation has moved to folder 3 (which should work just fine)
You coudl rename folder 1 to folder 10 and then see what happens. Avid should make a new empty folder 1 and create media in there.
T 07581 201248 | E [email protected]
You don't have Spotlight indexing the drive or Time Machine running do you?
