Latest post Tue, Feb 17 2015 11:45 AM by A.F.. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Oct 24 2013 10:45 PM
    • Eriah
    • Joined on Thu, Jan 8 2009
    • Posts 16
    • Points 220
    Nudge clip shortcut broken?
    Hey everyone.  I'm using MC 7.0 on Mac OS 10.8.5.  I'm having a weird situation where the nudge clip shortcut is only working if I'm nudging to the left.
    I select the clip with the smart tool (red segment mode).  Comma will move clip 1 fr to left, M will move 10 fr.  But period and slash don't move it at all.  Is anyone else having this problem?
    I've checked my keyboard settings and I've not remapped those keys to anything different.  They're still set at the default trim 1 fr, 10 fr.
    Andy
  • Fri, Oct 25 2013 3:12 AM In reply to
    • smrpix
    • Joined on Wed, Sep 5 2012
    • Posts 1,515
    • Points 18,905
    Re: Nudge clip shortcut broken?
    Turn off the yellow arrow in the smart tool and you should be able to move both ways.
    i9 12th generation, GeForce 3070, 64GB RAM [view my complete system specs]
  • Fri, Oct 25 2013 10:36 PM In reply to
    • Eriah
    • Posts 16
    • Points 220
    Thanks for the tip.  That indeed does work.  It's stupid that I can only have the overwrite segment mode active, but it works.  It seems like every time avid comes up with something to make editing easier, they do something else to make it harder.
    Andy
  • Fri, Oct 25 2013 10:40 PM In reply to
    • smrpix
    • Posts 1,515
    • Points 18,905
    This doesn't make a lot of sense to me either, but I discovered it a while ago and happy to pass it along.
  • Fri, Oct 25 2013 11:51 PM In reply to
    Eriah:
    Is it? Have you thought about how would Avid break any adjacent  clip (if you even wanted it broken) if you could nudge your clip in INSERT (yellow) mode in one direction or the other. And would you then want the adjacent clips frames (that where nudged across) adding on to the other end of the clip you were nudging with?
  • Sat, Oct 26 2013 12:45 AM In reply to
    • Eriah
    • Posts 16
    • Points 220
    I'm not talking about nudging a clip in INSERT mode.  That doesn't even make sense to me.  I'm saying that nudging clips should work irrespective of whether or not the Insert mode tool is active in the smart tool.  After all, situational tool usage is the whole point of the smart tool.
    The only reason to select a clip and nudge it with the keyboard is so you can slide it's position in the timeline with frame accuracy.  That's all I want to do.  When I select a clip with the smart tool, that's only what keyboard nudging should do.  It shouldn't matter that the insert mode is available on the smart tool when you select a clip to nudge it.  It should just perform a nudge.  What's so difficult about that?  FCP has been doing it for it's entire existence.
    BTW, you CAN nudge the clip with INSERT mode active in the smart tool.  But it only moves one direction.  It's either a poorly thought out feature, or it's broken.
    Andy
  • Sat, Oct 26 2013 3:40 AM In reply to
    Eriah:
    I never use smart tool. But out of interest I just tried it and you are right on a Mac here with 7.0.2 when insert is selected it will only move to the left.
  • Wed, Jan 21 2015 11:24 PM In reply to
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 653
    • Points 8,270
    Ok I just encountered this and found this post on a google search. I use the smart tool and would prefer to be able to nudge either way on the timeline but at least I know now
  • Tue, Feb 17 2015 11:45 AM In reply to
    • A.F.
    • Joined on Sun, Feb 1 2015
    • Posts 3
    • Points 15
    Same issue on AMC 8.3 on a Mac runnnig 10.8.5.
    It is very anoying to switch on and off the Insert tool everytime you try to nudge a segment to the right.
    This should be solved in upcoming updates
    AMC 8.3 * Mac Pro 2009 (2 x quad core @ 2,26 GHz) * GTX 680 * 22 Go ram * BM Intensity Pro 4K * [view my complete system specs]
