Latest post Tue, Nov 12 2013 10:40 AM by tonyjover. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Oct 17 2013 4:29 PM
    • tonyjover
    • Birmingham UK
    • Posts 397
    • Points 4,735
    • Moderator: Avid DS
    Avid DSv11.1.1 now available for download
    Hi all,
    Avid DS 11.1.1 software is now available on the Download Center (login and password required).
    This maintenance update is live today, October 17th, 2013
    Who is Eligible:
    This final release is an update to DS versions 11.0 to 11.0.2, and DS 11.1.
    Documentation:
    The general documentation is available on the Avid DS Support Center
    Avid DS 11.1.1 supports:
    • Avid Media Composer 7 for conform operations and ingest of unsupported formats in Avid DS
    • Avid ISIS 5000 / 7000 4+ for shared storage, including dual-1Gb and 10Gb
    • Avid Interplay 2.7 and 3.0
    • AJA Kona 3 (Xena2) and 3G Media I/O hardware
    • Avid Artist Color and Transport controllers
    Licensing:
    Avid DS 11.1.1 requires a new license activation if a customer is upgrading from version 10.5.2 or earlier releases.  If you currently run any 11.x releases you do NOT need to reclaim a new license.
    Important Note: The web links on the Avid DS Support Center are being updated as is the Knowledge Base.
    Avid Media Composer bundle:
    Avid DS customers upgrading to Avid DS 11.x through the Download Center are entitled to receive one Avid Media Composer software upgrade license to version 7. The license can be requested by completing the Media Composer section of the License Request form on the Avid DS Support Center. Should you have any immediate Media Composer licensing issues, the software has a built in 30-day trial allowing full control of the software.
    Where to Download?
    The DS 11.1.1 Software can be found on the Avid.com Download Center (login and password required) and is located in the “Avid DS” folder in the Product List.
    Cheers,
    Tony
    Filed under: , ,
  • Mon, Nov 11 2013 9:57 AM In reply to
    Re: Avid DSv11.1.1 now available for download
    Dear Tony,
    I would like to know if installing MC 7 on the same workstation as DS 11.1.1 is supported.
    I have a customer that has an issue with the drivers of the Kona 3G.
    The default DS installation suggests to use the 10.1.0 build 16 64bit Kona driver which works fine with DS but doesn’t work with either MC 6 or MC 7 for video preview. If he installs the AJA_Win_Drivers-10.4.1-x64.msi  and the AJA_OpenIO-10.4.1.msi he has a video preview in MC7 but DS gives a HAL error.
    Thx for any info.
    Avid reseller ACSR at Telmaco
    http://www.telmaco.gr/en/
  • Mon, Nov 11 2013 2:24 PM In reply to
    • tonyjover
    • Birmingham UK
    • Posts 397
    • Points 4,735
    Hi Jeroen,
    Yes, DSv11.1.1 and MC 7 can co-exist.  I have them both on my system.
    The correct AJA driver is 10.1.0.16 and will work fine for MC, but your customer will need to start the AJA service when he wants to use MC with the AJA.  DS stops the service for itself and doesn't restart it when it exits, so you have to do that manually if you want to use MC with the AJA.
    Obviously, he shoudn't try to run both DS and MC at the same time.
    Regards,
    Tony
  • Mon, Nov 11 2013 6:43 PM In reply to
    Thx Tony,
    Next to the device driver, which open I/O driver do you use on your system?
  • Mon, Nov 11 2013 6:58 PM In reply to
    • tonyjover
    • Birmingham UK
    • Posts 397
    • Points 4,735
    Not sure I understand the question.  All I have ever installed is the DS-Supplied AJA 10.1.0.16 retail driver.
    Tony
  • Mon, Nov 11 2013 7:07 PM In reply to
    That's strange. MC requires and Open IO driver to be able to access the Kona 3G.
    http://www.aja.com/en/products/kona-3g#support
    On this page are the windows device drivers and the IO drivers for MC.
  • Mon, Nov 11 2013 7:30 PM In reply to
    • slabross
    • Montreal, Quebec, Canada
    • Posts 938
    • Points 9,690
      Moderator: Avid DS
    Although it is true that many users operates both DS and Media Composer with the common AJA card on the workstation, engineering's official validation is only for DS to use the AJA driver and Kona card and MC to only be used for its software-only option.
    If you decide to use the AJA hardware and driver for the MC option on an Avid DS workstation, this is not supported by Avid.
    Sylvain Labrosse
    Principal Expert | Services and Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    Create cases online now at  csportal.avid.com
    It's fast, easy and effective!
    We're Avid.  Learn more at www.avid.com
  • Mon, Nov 11 2013 8:20 PM In reply to
    Dear Sylvian,
    Thank you for that clarification. I'm aware of the workflow design that DS<>MC was using pre-open I/O and that  MC was still included for that reason only.
    Now DS is EOL it doesn't really matter but still... Since the introduction of the Kona 3G on DS en open I/O in MC the question for a common IO base was a returning question on these forums and on other locations. With the recent certification of MC7 with DS 11.1.1 there was this hope Avid would certify a driver for both applications.
  • Tue, Nov 12 2013 10:40 AM In reply to
    • tonyjover
    • Birmingham UK
    • Posts 397
    • Points 4,735
    Jeroen van Eekeres:
    With DS being EOL I would think that highly unlikely.
    Regards,
    Tony
