Latest post Wed, Oct 14 2015 2:42 PM by fss_. 3 replies.
  • Wed, Jul 17 2013 6:50 PM
    • Steve Lewis
    • Joined on Fri, Jul 12 2013
    • Goleta, CA
    • Posts 9
    • Points 165
    Enable/Disable Effect
    I'm new to MC.  (just installed MC7)
    I am struggling with effects.  I can't figure out how to temporarily disable an effect so I can review before/after.    In FCP or Adobe, they provided you with a very handy "eyeball" button which simply turned any effect "ON" or "OFF".
    I also can't figure out how to remove just one of the effects in the effect editor.  It seems I can't just select it in the editor and hit delete.  If I use the remove effects button in the timeline window, it removes ALL effects associated with that clip, which is frustrating.
    Can someone help me out?  Thanks!
    Favorite film:  2001: A Space Odyssey
  • Wed, Jul 17 2013 8:08 PM In reply to
    • RUD ONE
    • Joined on Thu, Dec 14 2006
    • Milwaukee, WI
    • Posts 216
    • Points 2,595
    Re: Enable/Disable Effect
    Generally in the effect editor window there will be a check box for bypassing the effect
    MCA v4.0.5,HP XW8200, Adrenaline [view my complete system specs]
    Rud One - Milwaukee, WI
  • Wed, Jul 17 2013 10:12 PM In reply to
    • siencs
    • Joined on Wed, Oct 17 2007
    • Aberystwyth, Wales
    • Posts 441
    • Points 5,210
      Avid Certified User
    And if you double click the effect clip it'll expand the nested view. You can then select the effect you want and hit the 'remove effect' button and it'll just remove that one.
    e2a - In effect mode you select the effect to remove by clicking on the relevant iteration of the clip. When not in effect mode you select it by choosing the appropriate track/s to target V1.1, V1.2 etc.
    MC Symphony 8.8.5 on MacPro 3GHz 8-Core Xeon 12GB RAM, OS 10.12.6, Blackmagic Ultrastudio 4K MC Symphony 8.8.1 on iMac [view my complete system specs]
  • Wed, Oct 14 2015 2:42 PM In reply to
    • fss_
    • Joined on Tue, Jun 16 2015
    • New York City
    • Posts 82
    • Points 930
    don't see checkbox , shame.
    You can also use dual split view when in FX editor mode ...
    iMac Pro 20159 // AMD FirePro D500 3072 MB // OS 10.14.4 // MC 2018.12.8 [view my complete system specs]
    keep on cutting
