Latest post Tue, Jun 11 2013 6:41 AM by luca.mg. 3 replies.
  • Fri, Jun 7 2013 7:46 PM
    • Fazz Powell
    • Joined on Sun, Dec 3 2006
    • Naples, FL
    • Posts 476
    • Points 6,550
    Media Composer 6.5 responding slowly after being stable for a year
    Hello - I have two 6.5.2 MC with Nitris DX on Z400s/64bit W7 and one of them has started to respond very slowly. Both use the same Terrablock 24x (in multiwrite mode). The media is 720p and it's a combination of P2 media and footage grabbed form tape. The codec is DvcproHD. When we start editing it's fine and then it progressively gets slower within about an hour. You click on almost anything and there's a delay of a few seconds. If you hit space bar, it's takes a few seconds to play. The keyboard has also checked out a few times, but it will work in other applications. I've checked the QT/Nvidia matrix and it's correct (it was off with QT 7.7.2, but I installed 7.7.3 with no change). We've run a full hardware diagonostic and it found nothing. We've reinstalled MC, updated the ATTO drivers to the Terrablock... nothing helps. Any ideas on other things to look at???
    And wow, didn't know about Larry. That is a huge loss for us all. :(
    Dan Powell
    MC 2020.06 w/Symphony option. BlackMagic DeckLink 12G, HP Z840 Dual 3.2Ghz/8 Core, 1TB SSD, 1TB Cache drive, 128GB Ram, Nvidia RTX2060 Super, BCC2020,... [view my complete system specs]
  • Fri, Jun 7 2013 8:19 PM In reply to
    • NYnutz
    • Joined on Wed, Nov 25 2009
    • New York City
    • Posts 414
    • Points 4,950
    Re: Media Composer 6.5 responding slowly after being stable for a year
    When the sluggishness begins, run the Microsoft Resource Monitor application (start->run. Type 'resmon', hit enter.)
    This will give you a much more granular view of where your system resources are being used than task manager. It sounds to me like you have a running application with a memory leak  or cpu/disk resource problem.
    Dave
    "A very big network"
  • Mon, Jun 10 2013 2:58 PM In reply to
    • mmullen
    • Joined on Thu, Nov 13 2008
    • Haverhill, MA
    • Posts 574
    • Points 6,645
    It's just the one system?  Are they working on the same projects?  Do any of the media folders for this specific system have a very large number of files?
    -Matt M.
  • Tue, Jun 11 2013 6:41 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 5,910
    • Points 70,010
    Is automatic update on on the slow system?
    Symphony 21.9, BM Intensity Pro 4k, Windows 10, i7-5930K, 32 GB ram, Quadro K620 [view my complete system specs]
    peace luca
