Latest post Wed, May 15 2013 8:06 PM by julesnurrish. 6 replies.
Page 1 of 1 (7 items)
  • Wed, May 15 2013 4:15 PM
    Academic Eligibility MC 6.5 EDU version
    This is not a purely technical question, but unfortunately I cannot find an answer to this question anywhere else on Avid.com.
    I purchased the student version of MC 6.5, but cannot use the full version until I provide proof of my academic standing (I'm a teacher). My issue is that I need to install the full version on a different computer to the one that I initially installed the software on (the trial version has currently expired).
    Once I prove my eligibility, can I install the full version on a separate computer? Assuming I will have to uninstall the previous version on the original computer, which is not a problem.
  • Wed, May 15 2013 4:26 PM In reply to
    • Posts 12,146
    • Points 262,410
    • ! Avid Employee
      !Avid Customer Advocate
      Avid Beta Moderators
      ForumsAdministrator
      Moderator: Edit on Demand
      Moderator: SSAI PHAI
    Re: Academic Eligibility MC 6.5 EDU version
    easy peasey
    Once you purchase and obtain verification from Identi-e, and are issued the system ID and activation ID for the Faculty license, you can install it on the same CPU or a different one than the trial was on.  you can even run it on both but only run one license at a time.
    Example - Install on CPU A and activate.  Deactivate on CPU A via the Avid License Control Utility.  Install on CPU B and activate.  Deactivate on CPU B via the Avid License Control Utility
    Rinse and repeat.
    Sr. Director | Customer Experience and Community [view my complete system specs]
  • Wed, May 15 2013 6:26 PM In reply to
    great thanks!
    i've received the system ID and activation ID for the license. i just tried using it on a different CPU and it's neither accepting the new activation code, and when i use the one i received on the card i received with the software (ie the download code), i get the message that this code has already been used on a different system. i haven't deactivated avid on CPU 1 yet, so you're saying that i need to deactive avid on CPU 1 before i can install on CPU 2?
  • Wed, May 15 2013 6:35 PM In reply to
    • Posts 12,146
    • Points 262,410
    • ! Avid Employee
      ForumsAdministrator
    Yes!  thats what you need to do.
  • Wed, May 15 2013 7:25 PM In reply to
    And is the Avid License Control Utility within the program itself? I don't have internet access on CPU 1 so can I still deactivate on that machine?
  • Wed, May 15 2013 7:45 PM In reply to
    • Posts 12,146
    • Points 262,410
    • ! Avid Employee
      ForumsAdministrator
    Email me the system ID and I will do it for you.
    marianna
  • Wed, May 15 2013 8:06 PM In reply to
    I just talked to Avid support and they activated the software for me over the phone. Thanks for your help!
