Latest post Sat, Jun 1 2013 12:46 AM by mds7558s2. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Apr 29 2013 8:46 PM
    • jpottenger
    • Grand Rapids, MI
    • Posts 39
    • Points 520
    Matrox MX02 Mini - Monitor not displaying through HDMI - Input timing wrong
    I recently updated from Media Composer 5.5 to 6.5 and updated to the latest (fully supported) drivers for my Matrox MX02 Mini with Max.
    I can calibrate the monitor, but when I boot up AVID, my monitor (A Dell 19" computer display with an HDMI input) displays this error Message:
    "The current input timing is not supported by the monitor display. Please change your input timing to 1600x900@60Hz or any other monitor listed timing as per the monitor specifications."
    This monitor was working fine before when I was using the older verison of AVID and the older driver. Is there a setting that I'm missing?
    I'm currently displaying at 720p 59.94 fps RGB Native out of the Matrox (but I've tried other resolutions and they don't work either). This was the only setting that worked for calibration. I've tried other settings without calibration in AVID though and they didn't work.
    Help!?
    Media Composer 2022.7 | AMD Ryzen 9 3900x 3.80 GHz, X570 Aorus Master, 64GB DDR4 RAM, GeForce RTX 3070 Ti. Windows 11 Home 64-bit OS [view my complete system specs]
  • Tue, Apr 30 2013 1:19 AM In reply to
    • lunalobo75
    • Los Angeles, CA
    • Posts 278
    • Points 3,265
    Re: Matrox MX02 Mini - Monitor not displaying through HDMI - Input timing wrong
    Are you using Matrox Drivers 7.1.0.1294? I wouldn't use 7.3.0.1822; although 7.3.0.1822 may work, they were optimized for Telestream. Matrox Drivers 7.1.0.1294 were optimized for both Premiere CS6  and Avid 6.5.
    HP Z800 MC 8.3, Adobe CC, Windows 7 Ultimate 64-bit SP1, 2 Hex Core X5650 @ 2.67GHz, 48Gigs Ram, NVidia Quadro K4000, Sandisk Extreme 240 gig SSD System... [view my complete system specs]
  • Tue, Apr 30 2013 4:10 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Threads like these are almost impossible to answer when not knowing the system specs and driver numbers, adding those to the user profile before asking is always a good start.
    It does however seem as that external monitor not supports 1080 x 1920
    Tomas
  • Mon, May 6 2013 6:38 PM In reply to
    • jpottenger
    • Grand Rapids, MI
    • Posts 39
    • Points 520
    I had my system specs in the wrong field.  Do they show up now?
    I think I figured out that it was because I was using a computer monitor that it wasn't working.  I tried HDMI into a portable LCD screen and it seemed to work...
    Also I was using the drive suggested above.  Not the latest "Beta" one.
  • Mon, May 6 2013 6:49 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    System specs are visible now, actually similar to my old work horse.
    My guess for that previous screen to be to small seems to be correct, doesn´t matter if it is a computer screen or not, it needs to support 1920 x 1080 for the Matrox unit to work well.
    Tomas
  • Mon, May 6 2013 7:04 PM In reply to
    • jpottenger
    • Grand Rapids, MI
    • Posts 39
    • Points 520
    Yeah it is a smaller screen ...  Thats likely the problem.
  • Sat, Jun 1 2013 12:46 AM In reply to
    • mds7558s2
    • Hopewell VA / Fort Lee Virginia
    • Posts 23
    • Points 335
    I am sorry to trouble you with my problem. I am using avid mc6.5 and the matrox02LE and I can't get my matrox to see any of my equipment that I attached to it. I am using the pansonic AJ-D850p, with bnc output, xlr audio imputs. Please help. I woudl like to get it up and operational soon.
    I can be contacted thur my email address:  [email protected], if you contact i will reply.
    Michael Smith
    (Work Computer) Window XP Pro, 2gig of RAM, P4, 130 gigs of hard drive (Home Computer)XP Pro, 2gig of Ram, 1TB internal Hard Drive, 1TB external... [view my complete system specs]
    Michael D. Smith
