Latest post Wed, May 1 2013 8:30 PM by Larry Rubin. 16 replies.
Page 2 of 2 (17 items) < Previous 1 2
  • Wed, May 1 2013 7:59 PM In reply to
    Re: Playback issues in 6.5
    No Red Avid AMA plugins installed, althought that link you sent me says that plugins are installed if using MC 6.5. Are the plugins required to be able to re-link media?
    I am targeting the root R3D folder when I try to re-link.
    Just to be clear about where the media is and where it came from: the raw footage was transcoded from a shuttle drive, then the same raw media was copied to a separate drive (drive #2). In Avid, the AAF/MXF files point to the original location of the raw media (the shuttle drive), so I need to point it to drive#2.
  • Wed, May 1 2013 8:30 PM In reply to
    julesnurrish:
    To the best of my knowledge yes, they are. So definitely download and install the appropriate plugins.
    julesnurrish:
    Try selecting all the R3D clips in their bin, then hold down CTRL + SHIFT (CMD + SHIFT if on Mac) go to the clip menu and select "unlink". Then attempt to relink to those clips targetting only drive #2.
