Latest post Tue, Mar 26 2013 12:00 PM by chuckkahn. 28 replies.
Page 1 of 2 (29 items) 1 2 Next >
  • Wed, Jan 9 2013 5:42 PM
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 13,346
    • Points 160,330
    Mac Matrox driver 6.52
    I think you should try this one from the open Matrox beta, best 64 bits so far
    Quote from Matrox
    We have a public Beta of 3.3 available on our user forum that someone could
    use with Media Composer 6.5.  You can get it here,
    http://forum.matrox.com/mxo/viewtopic.php?t=9545
    We put this up to address an issue with Compressor but it will also work
    Tomas
  • Thu, Jan 10 2013 9:31 AM In reply to
    • Hansa
    • Joined on Tue, Sep 5 2006
    • Edinburgh, Scotland
    • Posts 452
    • Points 5,690
    Re: Mac Matrox driver 6.52
    Do you think this may work with MC 6.5.0 as well has MC 6.5.2 or do I have to upgrade before testing it?
    Avid DNxIO, 2.7 GHz 12 core late 2013 Mac Pro, 64 GB Ram, MC 2021.6 Ultimate, OS 10.14.6, LaCie 24 TB RAID. 3.5 GHz 6 core late 2013 Mac Pros x 5, MC 2021... [view my complete system specs]
  • Thu, Jan 10 2013 9:40 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    As 6.5,0 was the very first version I would recommend that you update, lots of bugfixes with 6,5,2 and also a better response with the Matrox unit.
    6.5.0 will work though.
    Tomas
  • Fri, Jan 11 2013 3:11 AM In reply to
    Tried this with MC 6.032... Not sure if it's supported but it's a great improvement over the last driver. I will test drive more today...
    Multiple Mac systems, MAC Pro, MacBook Pro's, OS Mojave, AJA IO 4K, T-Tap. [view my complete system specs]
  • Fri, Jan 11 2013 6:37 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Please do David, should be about the same fixes on 6.03.2 as on 6.5.2
    Tomas
  • Fri, Jan 11 2013 2:03 PM In reply to
    • nigelad
    • London UK
    • Posts 589
    • Points 6,850
      Avid Certified User
    Wow - thanks for the heads-up!
    I've been waiting and looking for decent new Mac drivers, but wan't privy to the Matrox comments about trying it with MC6.5
    Big Smile
    NEXIS E4, MC v21.6 on Mac OS 10.15.7 [view my complete system specs]
  • Fri, Jan 11 2013 2:33 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    nigelad:
    Big Smile
    I´ve been testing these for a while on the Mac side and I think it is safe to go, audio scrubbing now, as a contrast to the past, actually works even better on the Mac side than on the PC side, at least here
    Tomas
  • Sat, Jan 12 2013 3:12 AM In reply to
    Tested all day yesterday on MC 6.0.3.2 and glad to say I can nactually edit with Matrox box attached! Scrubbing is much improved and audio meter is in sync. Occasionally the system will hang for a few seconds but then seems to recover. Also still get some error messages with in the monitors in color correction mode but again system recovers by clicking to another clip. It's still not perfect but much improved.
  • Sun, Jan 13 2013 5:40 PM In reply to
    • gorky
    • Joined on Wed, Nov 16 2005
    • Posts 154
    • Points 1,880
    Just tried and for me it's still awfull. In PAL projects playback is normal on HDMI output, but on desktop there are dropped fames every sec. As I understand there is a incompatibility between 25 fps and 60 Hz of Macbook display. The same on Mac pro with old Cinema HD.But without Matrox desktop playback is ideal! And awfull scrubbing of clips at large  time scale, so I can't search for necessary frame or plan. About trimming - not for work.
    Just buyed Aja Io express because can't wait for ideal drivers...
    MacBook Pro (16-inch, 2019), 2,4 GHz Intel Core i9,32Gb RAM, AMD Radeon Pro 5500M 8Gb, OSX 10.15.3 [view my complete system specs]
  • Sun, Jan 13 2013 6:38 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    gorky:
    Never heard of
    gorky:
    and that would fix that Mac incombatibility ?
    Tomas
  • Sun, Jan 13 2013 9:57 PM In reply to
    • gorky
    • Posts 154
    • Points 1,880
    Sorry, what incompatibility?
    If do you mean "25fps - 60Hz", Blackmagic Intesity Pro, for example, is free of that bug.
  • Mon, Jan 14 2013 7:19 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    gorky:
    So, if you say that both BM and AJA have fixed a bug that you claim is Apple related I would just use one of those cards.
    If you want to have your Matrox box functional with an Apple bug that I´ve never heard of, flashing firmware after a driver update is something that have helped other users, you have to do it manually on the mac side and it´s all in the manual, situated at the same place as the drivers.
    If that doesn´t help a Matrox support call is your next step, they will ask you for system specs and OS so be prepared to have those specs available.
    Tomas
  • Mon, Jan 14 2013 9:46 AM In reply to
    • gorky
    • Posts 154
    • Points 1,880
    I did not tell that it is Apple bug. It is Matrox bug, because without Matrox everything it's alright.
    And in MC 5.5 with Matrox everything it's alright.
  • Tue, Jan 15 2013 3:47 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 13,346
    • Points 160,330
    Matrox driver 3,30..0067 officially released now and certified to be used together with Avid 6,03 and 6,5,2
    http://www.matrox.com/video/en/support/downloads/
    Tomas
  • Tue, Jan 15 2013 10:29 PM In reply to
    • gorky
    • Posts 154
    • Points 1,880
    Just tried. The same as previous beta in that thread. It's a pity.
